There was another time constraint involved in the changeover.
Someone in the accounts team is leaving and the replacement started this week, so they started training them fresh on the new system (they're already comfortable with the new one (Xero) but have never used the old system (MYOB Premier v19 via TS))
there a few ppl here who have been to SG.
Any-one know a hotel (other than transit ones) that lets you check in any time and check out 24 hours later? not 3 pm check in 10am check out.
for some reason my travel agent messed up and booked my trips on 2 separate trips so cannot check luggage all the way though.
land in SG at 6am fly out at 11 pm.
So need somewhere to store luggage/get some sleep/shower after eating too much.
all the ones I know of are in the terminal which I cannot use
so the transit hotels are after you have cleared customs.
Which fine normally as bags checked all the way though I stay in the cleared area and I can use them (the ones in SG are very nice, sub $100 and you can even use the pool)
this time (on the exact same flights as last time) they booked on separate tickets
So I have to leave the customs checked area in SG, collect luggage, but I cannot check them back in till 3 hours prior to my flight so 8pm.
thus I have 13 hours between that I am stuck with luggage.
my fall back is to take them to the office dump in my bosses office and be a tourist for the day
would like some sleep tho, red eye flights 2 nights in a row leaves Martin grumpy
there seems to be one opposite changi village hawkers market but you have to book direct not online so that could work.
So handful of containers landed on site. Made a wall with them.
Someone put on Kenny Loggin's Danger Zone this morning, but I think his song Playing With The Boys would be more appropriate
18's dont feel big enough for the gloria now... 19's would be nice so had a look at how much step lips would be to re-barrell. faark cheaper to buy another set brand new in specs I want. oh wait, theyre discontinued after being in production for 2 years :|
other wheels I really like only come in 20's. heaps of 'mericans run 20's on their M45 and it looks balls, but if done right... could be v nice. would need like $2.5k in suspension arms to get maaad fitment though.
would love to look similar to this (not that low):
1525445_792861030828141_2842875914403493
I sized up the wheels and without too much hassle (just need a bit of stretch) should be able to get 110mm dish on the rear and ~90 on the front.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
