Ricky Muir comes across in a Palpatine, ulterior motives kind of way, but you cant argue with logic. and when he opens his mouth, he doesnt make a fool of himself or talk utter shit while dodging questions.
yet to look into sex party. might read one of their pamphlets tomorrow while im handing them out
So I'm technically the First Aid Officer here at work, if there's an incident I am the one that it trained to respond with First Aid Training etc...
Not 100% sure exactly how Award rates work, when it comes to IT jobs in Private companies.
Apparently, as part of the Award that I would fall under as an IT worker, this should mean I get an extra $11.75/week for taking on this additional responsibility...
As I'm getting paid at a rate that is well above the award, does that mean I'm still entitled to the extra $11.75/week? Because I've been taking on that responsibility with no additional pay since Mid 2008... :/ (~$4888)
Thoughts?
cop it sweet I say.
put First Aid Officer on resume. receive training every year on company expense.
if you're not the only one in the company with it, ask the person if they get anything extra.
subscriber only article apparently.
no idea who I'm voting for tomorrow either, might do a dezz and draw a cock and ballz instead
just read up on the beliefs and policies of the Liberal Democrats. some interesting ideas, but overall seems to have learned nothing from how 'murica operates. 'murica.
summary:
Privatise just about everything.
Free media, free speech, pharmaceuticals taking over the country
cheaper childcare
less tax
no minimum wage, retain OH&S standards, but thats about it.
No on-going foreign aid
No benefits for Torre Straight Islanders or Aboriginals
legalise the ganja
smoking indoors
less national standards, and focus on competitive states
basically, government spending would be more than halved, but a lot of stuff would go to shit.
Pirate party seem to be on the money with most things, but dont really bring much new to the table other than internet and privacy.
Sex party seem ok, albeit more of a muchness to the major parties. dont like their policies for assylum seekers, but interest in nuclear energy is good.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
