If he has to die, I want Waleed to have a more ironic death, rolled by an abo or stabbed in the throat by a refugee, severely limiting his virtue signalling abilities
35 minutes ago, joeyjoejoejuniorshabadoo said:
Ah, replied about P Plate Status on the Atom is listed as exempt, not seeing that there was another car posted after it (the Lambo) which is most definately banned.
im sure you Philistines are going to hate on this, but finally found companies in japan that do styles that I had in mind.
behold: http://www.sensebrand.jp/cutter/cress.html?height=530&width=640
Ain't nothing wrong with that ^
Does yours have a single exhaust or both sides? It the bumper hole the same profile as the tips? If it doesn't match the curve, it looks stoopid and out of place.
^ those are things im going to have to work out.
for starters, 59,000 yen gets you two sets (reversed design) i only have one pipe so will see if I can buy one only. apparently its 250mm wide so need to see if my recess is that wide or how much it will cost to make it larger (and not ugly).
apparently the trick to unsymmetrical tips is to have it match the slope of the tail lights on that side... not sure how that works but going to look into it.
Yeah, I saw that and chose to keep addblocker on.
The whole reason that I initially installed addblocker in the first place was when Christian put adds on here that if you accidentally put your mouse over would cover half the screen and then have to be closed which would happen ALL the time. Heaps of people complained and he chose to keep them
I'd say so Leeroy, I mainly use it for annoying pre-video ads on youtube etc.
Also handy when I was at anal workplace blocking out peoples car pics in sigs so no one would realize I'm on a car forum
Enjoying the price surge for 33Rs...none on carsales for less than 24k and that's a shitty example. Didn't think it would happen this soon; almost on par with 32R pricing. Can't believe my mate let his HKS 2.8 stroker go for mid twenties.
Not that they'll necessarily get what they're asking, but I remember when these were advertised 16-17k at the low end. Amazing that so many only have 40,000km on the clock :whistling:
52 minutes ago, Leroy Peterson said:
33R's were like 22-25k before I bought the pulsar, that was only 3-4 years ago.
#noregrets
Yeah that was during their depreciation fall; same thing happened to 32Rs, which were down as low as 12k...then the numbers started diminishing and the prices started appreciating.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
