On 7/6/2016 at 1:05 PM, Birds said:
Simon...job updates?
To be revealed in the coming weeks...
They're currently trying to avoid paying me nearly $5k worth of backpay for First Aid Officer Allowance... It's fun as there are interesting developments every day and I no longer give a crap
putting new master cylinder and braided line on my bike.. been too long since I done mechanical thingz
inb4 i've got no brakes
also is 5 year old unopened bottle of brake fluid okay to use?
Edited by UNR33L
Taste it and find out.
I'm sure it would be given how long the stuff sits in cars for, but also given how much bikes depend on brakes to stop at high speeds and save the rider's life...you might wanna spend $30 on some good stuff?
Make sure the DOT rating on the bottle matches what the brake system is expecting (will be printed on the top of the reservoir lid, but if the foil seal hasn't broken then it hasn't been exposed to air and should be fine to use. If it was me though, I'd buy a fresh bottle, especially considering the price.
Also, have you considered tasting it to verified its quality?
As long as the type is the same...
DOT 3, 4 and 5.1 are increasing quality/grade of glycol-based fluid, they are backwards compatible, but not forwards compatible. eg you can use 3, 4 and 5.1 in a system designed for 3, but not 3 in a system designed for a minimum of 4.
DOT 5 is a silicone base fluid, and should not be mixed with anything else if you plan on protecting the squishy parts of your body.
8 minutes ago, HEKT1K said:
New housemate has been selected
Hope living with a stranger isn't as bad as Alvin has led us to believe
Alvin lacked style and substance, which is why he had trouble with strange housemates
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
