5 minutes ago, Leroy Peterson said:
Moh will pay more than $30 for jetski. Tax time is a good time to sell to Moh actually.
Maybe do straight swap for the BMW?
LOL
plan falls apart when you realise the model of Jetski Tradie Dezz bought.
Would still be worth more than Moh's 7 series
edit: and also a better daily than his R32
1 hour ago, dezz said:
I shouldn't have bought a brand new car, delivered in the middle of winter... I don't wanna take it outside and get it dirty... /paulR33
Drive the f**king thing already
Very happy with the 100,000km of hard driving I've gotten out of my GTS-T. If you excuse the head gasket for a track day it's cost me two bits of fk all to maintain.
Thanks for getting in touch with us. For Opti-Coat Pro+ application on your new VF2 SSV Ute, there are a couple of options to choose from:
Bodywork
1. Opti-Coat Pro+ (Base Retail Installation) - $945
Per the standard install procedure, this package includes a single-stage paintwork enhancement which is primarily designed for deep cleansing of paintwork for better bonding, minimise light marring and scratches and amplify gloss and reflections. It comes with the manufacturer-backed 7-year warranty on our national network of authorised installers.
2. Opti-Coat Pro+ (Bon Vivant Level of Installation & Correction) - $1295
The key difference is that we will provide a true multi-stage paintwork correction to ensure a practically defect-free bodywork. This means we can chase after deeper surface defects such as bird dropping etchings, water spots, deep random isolated scratches and swirl type scratches.
If you would like us to assess your vehicle to help you decide which option to choose, we can do so when you bring your vehicle in on the first day of the job.
Wheels
You also have the option of coating your wheels with Opti-Coat Pro+ too. Providing you the benefit of easier cleaning and preventing iron brake dust from pitting the rims over time, coating wheels on a vehicle is almost a necessity. Coating the wheels as an analogy, is similar to the Teflon layer on your frying pan, making it easier to clean and the surface more non-stick.
Faces-only vs full-wheel coating is $45 and $75 per wheel, respectively. With the full-wheel coating service, we'll be able to coat your callipers too (complimentary) as a method of colour locking them and prevent fading over time.
BECAUSE you are a referred customer :), we will coat your glass and floor mats with Polishangel 9H and Gtechniq Smart Fabric, free of charge, worth $190.
Wanting the car for 4 days, sounds like a pretty involved process, unless they just let it sit there for 3 days to make it seem that way obviously...
Also hearing a lot of good things about http://dansgaragedetailing.com online and from a mate who had his black car done there a few years ago...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
