2 hours ago, emts said:
Don;t call these guys Hackers, thats giving them way too much credit, it is script kiddies doing a Ddos via a zombie network. (if it was an attack)
It's that easy even Birds could do it.
http://www.symantec.com/connect/blogs/renting-zombie-farm-botnets-and-hacker-economy
the funny thing is load testing is a very similar process, get a whole bunch of boxes and start loading/posting data to the site. monitor.
What is interesting is that this might not actually be a DDos attack just a crappy scoping exercise.
so apparently they estimates the traffic at max 1 million users per hour, so the load testing at 150% would be 1.5 million users.
now lets say there around 10 million users submitting online.
I would guess around 1/2 would have sat down in the evening and gone ok Fk it lets do it.
so 5 million in 2ish hours or much more than they scoped.
they could have Ddosed themselves with legit traffic.
that also said doing it in the "cloud" is meant to mitigate this as they can just virtually throw more CPU's at it till traffic is gone.
Exactly my thoughts, they essentially DDOSed themselfs, but they'll blame 'hackers' to hide their own incompetence and sweep it under the rug.
37 minutes ago, Kinkstaah said:
That's the thing though, most dynos have *peak* torque at ... I dunno, 4k? Usually when the car hits full boost, middle of the range.
If you backed power off in that range, your torque would not look like that. Instead of being 620nm at 4k then bleeding off to 500, you could have it peak at 500 and stay at 500 the whole way through the rev range.
Look at most people's dyno sheets, the max power figure is not where the most torque is.
At least in my car having huge power at 4k only rips tyres anyway. I'd probably result in a car which is faster through being easy to drive, and won't smash gearboxes. I am aware that losing traction means driveline stress wouldn't happen anywhere near as bad, but usually 33 boxes die from stripping gears. Under load. Usually 3rd. Usually when cars are on full boost/torque and not losing traction anymore.
So my idea was simply to spread that out over the rev range instead of having it all come in hardcore when the turbo spools up.
Going a smaller turbo isn't an option for me, my car has the tendency to choke the living shit out of anything smaller than a GTX3582R. I had to run a GTX3076r with a limit of 5700rpm to avoid the car melting itself.
Ideally you'd just have a gearbox that can handle the torque. But rarely do we get exactly what we want in modding cars :P
So taking that idea one step further is to then set a specifi torque map in each gear, so as to not spin up tires in ow gear and stress on driveline..ie exactly what the new 488 is doing:
"To aid traction and allow the use of shorter, acceleration-enhancing gear ratios, each individual gear has its own torque map, the full 760Nm only available in seventh. "
http://www.motormag.com.au/reviews/1603/ferrari-488-review/
Yes that theory is sound if all you want to do is produce the kw figure without risking the gearbox. However, you're still tethering the performance of the engine...and not in the most efficient way. Something you'd be better off doing with a smaller turbo IMO and gaining the benefits of more response / less lag. Choking the turbo up top is simply the trade off for better performance down low - it sucks, but so does lag to some people. Don't take the engine speed that high; you don't have to when you're making full boost at 3000rpm. I choke mine at 6000rpm too, but by that speed in 2nd gear the drag race is usually over.
In an auto with traction issues it MAY make sense to manually restrict it, given you don't have the throttle control of a manual gearbox to control your wheelspin. But otherwise, all you're doing with a torque restriction is dyno queening. Given torque is a measure of rotational force and power is a measure of torque over time, you're removing the point of having a car that produces 400rwkw, save for dyno comps!
If Ferrari is doing it, it may actually be something that works..
Yes this would be a workaround where the gearbox isn't matched really for the engine. This is kind of an issue for skylines.
I don't think it would actually nerf the power, if I could choose to have my gtx3076r making less power (still 400 in a manual...) or a GTX3582 which I can rev out to 7500, the 3582 had a much meatier power band.
So even though the boost came on "later", I had more revs available to actually use it.
I mean choking in the way of 120KW of lost power in the 500rpm from 5700 to 6200. The concept however is quite sound and yes I agree, get a turbo that's just nosing over/making peak power realistically where you're going to be revving/using the engine every day of the week.
My throttle map/boost idea was only cause
a) I could (yay haltech)
b) I may need to with a 33gtst box
c) Traction means it isn't any slower.
End result would have it feel like a N/A engine and be extremely linear in power. I am fully aware that "more linear" really means "Less midrange" but if you're on the edge of grip at 75% throttle in the midrange anyway, there's no functional loss if you are 100% wot through that section and have your power more closely match what the tyre can actually keep in contact with the road.
And it may not explode the gearbox.
That said my auto has not exploded, and it has paddles to comfortably hold a gear anyway. Was just musing because the "GET A f**kING MANUAL" assaults me from all sides literally on a daily basis.
I think it'd be awful personally...like hitting a power brick wall. Pretty much how an 86 accelerates, but with a little lag to boot. Not lifting the bottom and top to be linear with the mid, but dragging the mid down. The opposite of converting to E85 haha. It might be alright in a circuit car where you're not concerning yourself with the first half of the rev range. Ultimately your car is still going to be quick, but I believe it can be quicker in more places with a smaller turbo. That said, I'm of the opinion that anything more than ~300rwkw in a GTS-T on street tyres is a waste, so I'm always going to push for smaller turbos.
The thing with a lack of traction is that it's better for the gearbox than grip. Grip is the resistance / inertia / holding the output shaft while engine tries to turn the cogs. Once grip frees up, the gearbox is safer (obviously sustained high RPM abuse will melt the bearings). Pretty much why AWD GTRs smash 3rd gear all the time in spite of it being internally much the same box as the GTS-T (grip and transfer case pressures). So as long as you're not putting that 400rwkw to the ground, I think you'd be alright with that box.
They had ballers on the Qantas inflight entertainment.
Started watching it..
kinda awkward when they come to serve you drinks and there full nudity and sex on the screen.
was good tho, preferred Entourage but its getting there.
  • Like 1
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
