GTS-T in for panelbeating, copped a free loan car cause being not at fault is awesome. Ain't that right Simon?
'16 Hyundai Accent with 2000km on it and new car smell. Shit has come a long way since the 90s. 6.2L/100km vs my 18-19 on E85...they can keep the Skyline.
That... is not right... not with Shannons, since it's not stolen I don't get a hire car. Booo. Do get a coupon code for reduced rates with Hertz, but thats about it
Lol. This from the most painfully rusted on R33 fanboy
Jestful remark is jestful. There's no joy in the Hyundai - don't know what dezz is raving about. Every CVT flare and disregard for speed bumps is soulless.
Why you going through your insurance if not at fault?
  • Like 1
Where is everyone from?
I'm super paranoid about mine getting stolen! I'm from dandenong though haha.
So with my nistune ecu am I supposed to be running a z32 ecu?
Ive got a standard rb20/25 afm on
f**k, do I need to spoon feed you through your whole build?
*1 R33 RB25DET Skyline
The original R33 RB25DET ECU cannot be used with a Nistune board
(a) We recommend sourcing an R32 Skyline ECU which is compatible. These ECUs require little modification and reuse existing O2 sensor, knock sensor and TPS sensor (TPS idle switch is replaced by soft switch in firmware) and come with RB25 base maps and are the recommended ECU for tuning
Nissan ECU Part numbers on front of R32 ECU case:
23710-04Uxx: Uses spare LED output to run VCT
23710-11Uxx: Uses fuel pump idle control output to run VCT
VCT modification information here
Note: Series 2 there is no IACV (Air cond output idle up control valve) output on these ECUs. Recommend wiring IACV solenoid directly to the AC relay (same as Series 1)
Note: Manual transmission models only supported. If using an automoatic transmission model R33 Skyline then reportedly the R32 Skyline automatic transmission control module will work
(b) Alternative option is the Z32 300ZX VG30DE (1990-1992) / Z32 300ZX VG30DETT (1990-1993) ECU
These ECUs use different knock sensors which will need to be disabled, some other modification including connecting both O2 sensors together and removing fuel temp input to the ECU are required. There are mixed reports with tuning these particular ECUs so we recommend using the R32 ECU where possible.
Modification information here
Part number listing information here
https://www.nistune.com/equipment-products-type2.php
So I actually picked up 40rwkw by putting a pod filter on.
I also picked up 750rpm of peak power response by having VCT actually work.
I guess it pays to test shit. Also pretty sure gonna die soon due to above two things.
  • Like 3
That's a load of shit from them...I didn't even involve my insurance company. Just a third party assessor / litigation lawyer who the panel beater referred me to. The woman who hit me admitted fault and her insurance company took on the liability, so everything I'm out of pocket after that is on her insurance, hence free loan car because I ticked the box that said I don't have access to other transport.
Involving the lawyers has turned $1000 worth of panelbeating into a several thousand dollar claim.
  • Like 1
Because I didn't trust the other guy at all, kept trying to avoid insurance... and I had to push to get the name of his insurance company... which turned out to be a broker. I don't have the time or knowledge to do it all myself.
So letting Shannons deal with it, then charge everything to the broker of the other guy.
On Saturday morning a 4wd behind me at a set of lights smashed his foot on the accelerator as soon as the lights went green, without realising that the first car (and thus me as the second car) hadn't started moving forwards yet.
Didn't seem like a hard hit, but once I got home and opened the boot, everything was way off from where it should be. Grrrrr.
Bathurst ticket went down a treat.
that said I drive a clapped out falcon ute, drink VB, and are moving to the country.
much prefer to be classified as a bogan than a hipster..
on a side note, my old Noise Cancelling headphones are officially dead, ordered some Bose QC35's should be a nice upgrade
  • Like 1
That's fair enough as that's also what your insurance company is for, and as the other party has been identified you're not liable for an excess etc. However they're still screwing you on the loan car and probably doing it because they know they might not recover costs from this guy and it'll only add to their bill.
It doesn't take much to cave in the Skyline rear end. My rear end damage that I've had for 2 years (crunched in bootlid and rear bar) came from my car slowly rolling backwards into a car with a bullbar...8km/h max. I'm getting this stuff fixed at the same time as the current front end damage, so should be looking nice again.
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
