Attempted to speak to telstra this afternoon about broadband options... Theyre already f**king shitting me.
There is no sales representatives, they instead sent me an sms with a link to their website. The page doesnt answer any of my questions. And what the f**k is wrong with number options? Voice commands clearly never work. Its like they want to prime their customers to abuse staff once answered.
  • Like 1
Good luck with that.
I'm convinced customer service at these large multi-level organisations is set up in the least efficient way possible so as to deter you lodging complaints, not unlike the process for contesting a traffic infringement via court.
With Telstra you get stuck speaking to frontline robots who handball you to other robots and with the automated SMS/email bullshit you end up with about 3 different case IDs and 4 different people assigned to each. If they can't resolve an issue you won't ever get told this, it will simply stay in the ticket queue forever and a day.
7 minutes ago, dezz said:
Tomorrow is the most important day of the week for share prices... I don't like to see red over the weekend... Even grey isn't as attractive as green
If news doesn't come for us tomorrow it will probably go up again because of Friday FOMO. Historically we've had news released early in the week, Monday/Tuesday etc.
London tonight will be a good indicator. If they continue the upward see-saw with us, I'm almost certain we'll open up again tomorrow.
Wasn't there any news in the 23 page release I told you to read on my behalf?
Even I read it.
All I got out of it was that the price crashed last time because they went from ~75mil shares to 3.1bil. I'm sure some major steak holders knew it was going to happen.
Mmmm steak.
Unless it's related to oil or drilling progress I don't care for annual/mid/quarterly reports. They say nothing anyone following the company closely doesn't already know.
30 minutes ago, Daz said:
Smashing it :)
Yeah it's been awesome, am very lucky. I still think the share is ridiculously undervalued given the company prospects and asset potential, which is why I haven't sold out. Just gotta think of the profits as reinvestment instead of taking it out.
88e is doing a good job of flying under the investment radar, which will send it into orbit if/when we cop good news and mainstream media starts reporting it. That's pretty much how it ten bagged last time.
  • Like 1
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
