Not that accurate...
I got tuned at 230kw (Safe tune due to an issue with the wastegate), then goes to RTR and makes 203kw on its first run 2 weeks later (same boost curve, cooler day)
At the end of the day, I learnt to ignore the numbers. If its making 300kw and doesn't have anything in the midrange, you'd be better off with 260kw of usable power.
  • Like 1
30 minutes ago, joeyjoejoejuniorshabadoo said:
Dissatisfied cause they couldn't afford the petrol to drive home from racepace
racepace is f**king cheap for the service you get.
i dont think theres any other shop that lets the apprentice suck your dick while you wait.
thanks borci, more cock for you tonight birthday boy
  • Like 1
What part of that makes RTR the more accurate one?
wondering why there is like 30 video files on my work phone... iphone "live" photos defaults to on. has to be one of the dumbest f**king phone features ive ever heard. retarded pricks.
  • Like 1
Comparing dynos is ultimately a pointless exercise and the fixation on achieving certain figures is dumb
So too is a ton of power if you're not making it grip or having it anywhere you're actually going to use it
I'd rather use the Birds measure of power - rolling drag races baby
inb4 new 33R has less power than the coveted 23.GTR
  • Like 1
lmfao
set of -5s with GTX cores have popped up... with RP equal length front pipe, basically a full kit
i know i want a single but twin GTX through a RP front pipe is hnnngggggggggggg
No it's not. You've worked on the twins properly now, and now you have a 25 stag. Sif it's not worth going single. And none of this "cops will ream me". You from Thomo. In a 4-door 32. Probably with your cousins in the car. Single turbo is the least of your worries. Just tell them you put 26 can covers on your 25. Done.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
