what do you hate about it hamish?
car stuff:
trying to find spark plugs with the thin thread style plug... NGK used to be able to unscrew the tip of the contact, but not anymore.
Martin: do you want a whole bunch of BKR8E's I bought and no longer can use?
Without thinking too hard about it:
Lack of throttle response
Lack of transmission response
Engine note
Lag
Heavy, horrible steering feel
No road feel
Hard, uncomfortable seats
Headrest permanently angled forwards
Lack of features
Streaming audio option disabled
Key flick thingy opens too easily
Indicators on the german side
Plain, ugly dash
Terrible driving position
Transmission in general
VW sales people
Ability to be locked inside car
Obvious planned obsolescence
The vibe
Mabo
  • Like 1
I assume by this you mean the left hand side...
I drove a workmates new civic the other day... Go to turn out of work and of course the windscreen wipers go. So I said "WTF, this is a japanese car, not european" and she said "Apparently it's the european model that we got here". I said, "but... but... it's Japanese"
Engine note
Lag
No road feel
Lack of features
Plain, ugly dash
VW sales people
The vibe
Mabo
Cup holders don't fit glass jars/milk bottles
  • Like 1
Actually they do... it's the cars best feature. There are 2 cup holders and the little bit in the middle slides back and forward to alter the size. It also doubles as a bottle opener
  • Like 1
Related:
https://www.dropbox.com/s/o07aa9k3sj1s6ov/Screenshot%202015-08-18%2009.56.26.png?dl=0
Edit: Cliffs for Hamish.
"It looks like you're in Australia, but are viewing our US-based site.
Would you like to go to the European site?"
Engine note
Lag
No road feel
Lack of features
Plain, ugly dash
VW sales people
The vibe
Mabo
So you bought the car sight unseen?
  • Like 2
So you bought something which is quite expensive, arguably well overpriced based on your above review, totally dissatisfying to own and which will continue to depreciate in value.
Conversely, my red independence days are comfortable, fit well, I like the look of them, as do most other people, and only seem to be appreciating in value.
Please tell me again how I'm a douchebag for buying my shoes
/Kermit sipping tea.Jpg
  • Like 1
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
