Matt Borci or anyone else
Been out of the loop lately. Looking for a new fully synthetic e85 compatible oil to replace my Castrol Edge 10w60
Figure i dont need the 60w now that i have an oil cooler and no longer track it.
Was thinking 10w40? Which Castrol Edge dont do
On 9/20/2016 at 7:22 PM, Birds said:
Did they have an option where we can pay $500 and you get arrested
i wish
On 9/21/2016 at 0:55 AM, Odium said:
Quick VWL fundraiser to cover costs....
yuuuussss
Penrite ten tenths racing 10w40
  • Like 1
Oil cooler doesn't change anything. Castrol Edge 10w60 all day every day.
  • Like 2
3 hours ago, Leroy Peterson said:
lol does this mean the wheels dont clear the brakes?
gonna finally bite the bullet and get simmons?
http://simmonswheels.com.au/wheeldetails.php?wheel=22-inch-simmons-om
yeh they were way off, 8mm spacer still wouldn't fit - I knew it going into it though
3 hours ago, Jonnoo said:
I got thrown off by the lack of price tag
like anyone here could afford em, too much lost on 88e
fair enough. it was more so on the street oil takes ages to warm up even with a thermostat and hardly goes above 75 to 80 on normal driving
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
