12 hours ago, dezz said:
IT kunce, does this VPN stuff work, and if so, what's a good one to use... Criterion - effective, easy to set up, not a rip off.
Another popular one is tunnel bear
11 hours ago, emts said:
apparently, I've only played with the android one as I only use it on my tablet
but there is a windows one as well.
assuming it the same as the android one it just a matter of install and enter user name and password
https://www.ipvanish.com/vpn-setup/
Martin knows his shit so this will be just as good / maybe better
11 hours ago, dezz said:
I pretty much only want it for downloading torrents... Keep seeing the ads on kickass/pirate bay etc... Been downloading torrents as normal without giving a f**k, but if it's only a couple $ a month to avoid any potential bullshit later then why not..
Express VPN seems to be the highest rated? $8.32/mnth for 12 months...
But do I then need to use something else to download torrents or do I just download through utorrent as normal?
Yep, VPN basically 'tunnels' you over to another network and acts like you're working / downloading from that location or network.
I'd be trialing and making sure you get good speeds, the biggest downfall with these VPN services (mainly the free ones) is it slows your speed right down, Martin mentioned 50mbps if that's true then you'll be fine.
Took car to suspension place, for front suspension being  abit crashy.
Advise is to replace entire coilover system, entire rear subframe, both rear wheel bearings and lockout bars galore - None of which they are willing to take on for any amount of money.
Good times.
Good times.
Why didn't the Haltech alert you to this before it was an issue?
  • Like 1
Didn't buy the optional suspension is f**ked sensor
16 minutes ago, Birds said:
I don't wanna curse Brett with your penchant for disaster, but maybe take it to Shockworks?
I thought about this but I was under the impression the setup I had was great. Certainly felt fine, though wanted to see what the Shockworks R34 felt like. I suspected nothing was even wrong with the rear end actually. Just thought the front was hitting the stops a bit too eagerly and was a little low.
But nope, apparently the rear is so bad it'd be 'suicidal' to drive it. I'd really rather not pay $5k to get it into an approved setup lol.
They just did a coilover swap on my GTS-T and the cost was very reasonable, so I guess if it's something inevitable for you, that would be a good starting point.
To be fair if I do go the whole hog and replace shocks and springs I would consider Shockworks or MCA really as the only two options to choose from. I may get away with a new set of coils, hicas lock bars and toe arms to suit, and two rear wheel bearings.
Still somewhat shit when my initial complaint to get checked out was "hm, the front seems to be pretty happy to hit bump stops and isn't low"..
Can anyone actually recommend a suspension place that won't go "Oh it's a sedan, I see your money and your questions are beneath me and please stop lowering the property value of my amazing shop"?
as this happens quite a lot
Good times.
werent you trying to convince me to buy it?
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
