I found the AD08R to be absolute garbage in that last turn trying to get any power down (lowered the boost as much as possible and had big issues)
That said, can confirm am noob driver. My suspension is possibly f**ked though, but 5kg front and 4kg springs at near stock ride height is pretty fkin boaty and non track optimal, like everything that I haven't near immediately changed after actually trying to use it.
Birds, turns out that "Catch can" was actually pretty much venting to the engine bay as that's where it was disconnected (back to the intake, at the intake) and just pissing oil everywhere. Bought a replacement with actual baffling that will actually be setup actually correctly to actually catch oil (or at least put it it back into the intake and not into the engine bay), and actually get some actual tyres for the next time. (i.e, Nankang AR-1)
Or just cheat and get a GTR for those slow corner exits
Also that chaser was parked literally next to me. Was a nice guy!
Greg, I followed your car down the main straight, into turn 1,2,3,4,5 and partly down the back straight and I thought it looked to be handling quite well. As far as traction out of the last turn, with the amount of power and torque you have on tap, throttle control is the key and yeah the biggest r spec tyres you can fit would be a good f**ken idea.
19 minutes ago, admS15 said:
Why did he need to get towed. What happened?
started blowing huge amount of smoke at end of the main straight so shut it off.
turned out to be a minor thing, over filled with oil
  • Like 1
I had turned the boost down so I was running a fair bit less than 415, more like ~320ish but the delivery is still much the same and first time ever out on the track in the thing, I almost put it into a wall on the back straight coming on power too, so that was why I went home to get the laptop to turn that boost down before death. Obviously a stall converter not the easiest thing to feather but it's 'doable' with some restraint.
It did feel rolly and sloppy as all hell, but maybe that's what everyone is dealing with and I should just learn to drive :D Sure was fun though.
1 hour ago, UNR33L said:
so where's the best place to buy AD08s? seeings as I need new rims anyways - dont they have a buy 3 get 1 free thing atm?
I feel like Hamish and me were the only ones that liked the NT05s
Dunno about best but Traction Tyres (inb4 Greg) sell them. Not cheap though. I got mine for $220 a corner a couple years ago but they were 2013 production so cheaper.
You don't have to go AD08s, RS3s are probably better value, but yeah much better options out there than NT05. Think Ric liked the Nittos too.
Yokohama buy 3 get 1 free special atm doesn't include ad08, only some shitty suv tyres. I got my ad08 through bob jane of all places, was actually better priced than traction tyres. I noticed the tyre factory advertising RS3 last week on ebay for 269 for 265/35/18.
Given I could plant 1st and 2nd on the street without breaking traction (without warming them up) in a 320rwkw car with 320rwkw at the wheels I was damn impressed.
edit: 320rwkw
Edited by joeyjoejoejuniorshabadoo
to add more 320rwkw
FWIW I found no real huge difference in NT05 and AD08R in terms of grip for the street. Housemate with RS3 and AD08R noticed no mega difference, maybe the AD08R lives a bit longer due to the higher cost so you aren't swapping as much.
No back to back laptime data etc though, all by that seat feel.
Been looking at RS3 as well, as usual barely any around in the sizes I want, sent a few emails this morning for some quotes, most with this response:
"Sorry they have no stock of either sizes. I have checked a couple of sizes close to the size you have asked for and stock very limited."
Seems to be more Invo / NT05s
http://www.ttf.com.au/#/shop/tyresbysize/245-35R19
Edited by UNR33L
edit: 320rwkw
This to me isn't so much evidence of NT05s being good but hub dynos being liars
2 minutes ago, UNR33L said:
lel
anyone tried the  Michelin Pilot Super Sport ?
tried them on a mates car and wasn't that impressed for the $$$
not bad, not great
121 mph trap speed @ circa 1550 kg inc fat-ass driver.
your move...
They are more luxury performance tyres, like the Continentals, where they will perform well in dry and wet but you also get less road noise than cheaper tyres.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
