Just now, Birds said:
They are more luxury performance tyres, like the Continentals, where they will perform well in dry and wet but you also get less road noise than cheaper tyres.
and if I remember correctly he whinged like a bitch about road noise for like a year
3 minutes ago, joeyjoejoejuniorshabadoo said:
121 mph trap speed @ circa 1550 kg inc fat-ass driver.
your move...
it's common knowledge that heathcote speed trap isn't accurate, mine was a few mph higher than all the other tuned 5.0s too
your move :P
edit: it's true, NT05s were noisey af
Edited by UNR33L
Which is why I always maintain it being undervalued
That oil price will inevitably be sky high again one day as the finite resource diminishes and even unconventional plays become worth a truckload. The market hasn't factored this in yet, hence minor OPEC shit gives a small push. If the rest of the world is banking on renewable energy offering an oil solution and you hedge against it...correctly...you'll be winning.
370 sets would take a while to get through
unless you had a 370kw 370z
  • Like 2
31 minutes ago, joeyjoejoejuniorshabadoo said:
INVO's are probably better street tyres for your power level though - will last like 5 times as long too
I did still have the skyline when I bought them
glad i didn't get a chance to fit them and gift the new owner a fresh set
  • Like 1
Not for a few more years at least. The OPEC announcement won't change a whole lot it just restored some confidence that something can be done to hopefully limit the Saudis and Russians trying to undercut the Americans. I think the Saudis are in trouble soon...
But this unconventional thing is a double edged sword. The more that is found and is profitable, the less finite the resource is. So looking 5 years down the track, I don't think itll get back to $100 a barrel. Everyone involved is looking to retire before then.
As for undervalued... Otto energy is exploring in 3 different locations, their great bear section of Alaska is next door to 88e and is further ahead in exploration but worth 4.5cents still. Due for some results in dec-jan. If it's not amazing news 88e will take a big hit.
12 minutes ago, HEKT1K said:
Move on pls Birds
My priorities have changed
I'm sorry that the theft of your vehicle hit me harder than it hit you
#insurancejob
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
