Does Taleb come on here anymore? waiting for pm response!
Leroy brah you're the new 88e pusher :P I'm just interested to see if Dezz will sell this time once it hits 7-8c :D
Edited by UNR33L
8 minutes ago, Leroy Peterson said:
88E in London saw 15% increase last night.
Plenty of ASX buyers in this morning. might get close to 5c today.
I should have bought back in properly at 3.9
At least my mini holding is making a recovery - never sell at a loss!
  • Like 1
once Birds stopped pushing and quietly said "im out, have fun fellas" i needed to make sure that he would regret it.
While also preserving his legs from the wrath of Dezz.
Haha I'll be back in soon enough, just playing the safe game on a potential fall to low 3s
I was afraid that the Dezz-monster would be at Sandown on the weekend, I prayed for Bird's legs.
Keep what you got and put it into a house with Leesh brah, maybe play with a little bit of $
Come hang out and buy near Clayton hang out with Sandown, Me Toby n Leeeroyy
Actually heard on the news the other night house prices increased 80% since 2008 :O .
Edited by UNR33L
Leroy brah you're the new 88e pusher [emoji14] I'm just interested to see if Dezz will sell this time once it hits 7-8c [emoji3]
Dumped it already, you didn't think this rise actually had anything to do with any OPEC announcement did you...
Yeah birds
16 hours ago, Borci88 said:
Greg thinking he needs more than AD08s is interesting to hear though..........
Watching some handheld video of my car at sandown (which is painful to watch) I noticed some oily looking smoke down the left side of the car.. where my catch can... wasn't... really catching anything.
Funnily enough, the left rear was the culprit all day.... and this was after turning the boost down to about ~300rwkw, after almost faceplanting the LEFT barrier on the back straight getting onto the fun pedal with the wheels facing straight...
hmmm..
Potential self-oil slicking my own tyres aside, WOT under 100 kmh isn't really possible in my car though. This is more of a "too much everything for 2WD" as opposed to anything else.
I wasn't able to even go WOT comfortably until the start line at Sandown from the last corner, which I doubt most people have to deal with when they are making 300kw, so that lends a bit of suspicion on just what that oily looking smoke was doing down the left side of the car.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
