I have a 180kmh speedo :P
However I could easily determine this from the logs on my amazing Haltech ECU to determine what the speed actually was, as it'd auto log such information for later viewing.
  • Like 1
My top speed was about 190-200km/h when my car was stock
Sorta miss track days, be curious what time i'd run now at Sandown with better tyres, suspension and current power
I have a 180kmh speedo [emoji14]
[emoji6]
If your mvss is correct that is. My Nismo speedo was showing 235, gps 221 and mvss from ecu log 202.( 221 being correct). Managed a 125.9 with wheelspin coming out of the slow corner after the back straight. 312 hubrwkw 475nm.
Greg I reckon your car on full boost with traction and balls of steel, would have to go 250+
guys,
sold a bunch of equipment to a bloke about 2 weeks ago, he presented a remittance advice slip at the time that looked legitamate so i let him collect, like everyone else.
anyway two weeks later and this shit still hasnt cleared.
anything that can be done? or do i kiss my money goodbye..
12 hours ago, Kinkstaah said:
I don't think it's realistic to expect to go WOT and have 0% traction loss when you make peak power at 4000rpm, I too turned down the boost as much as possible so I was running about ~300 and had to really feed it in. I would have loved to literally go 100% throttle as soon as exiting the last corner onto the straight and hold that all the way to turn 1 but that isn't happening. At least for me. If there is something to fix I'd love to know about it!
Get a turbo setup that isn't a piece of crap?
2 minutes ago, Kinkstaah said:
Yep, I shall go out and make less power and way more lag, that'll make my turbo setup less crap, that sounds like an ideal solution.
You've had like 10 death defying incidents this year alone, and can't get the power down at Sandown. Yes, it is a much more ideal solution.
  • Like 1
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
