i got southland carwash to steam clean my now-gone pulsar a while ago. Seats turned out good, but they sprayed the entire interior (radio and everything) with some shitty washing product that stayed sticky. I had re-go over everything with a damp cloth to get the stickiness out. it was like a pink, nice smelling soup kitchen happened inside the car. They even accidently left a bottle of it under the drivers seat. spastics.
1 hour ago, joeyjoejoejuniorshabadoo said:
You literally just bought an R32 in the exact condition as the car the guy is making inquiries about
nah the new one is worse lol.
its pretty bad but saveable .
1 hour ago, Kinkstaah said:
Dumb question, is there any good BUDGET detailers? Somewhere where you can just go on a very low notice and get a reasonable to OK job of interior detailing because majorly CBF and car looks pretty shit 95% of the time anyway?
By "good enough" I mean good enough to think "oh yep, that's cleaner now" but with 0 desire to actually take a photo of it.
In springvale cnr of westall and osbourne i think? next to GT hyperauto
$15 for a hand car wash. not bad considering it takes em like an hour
I wonder what the IT section at Telstra is like....
Would it be filled with ex-public servants who just dont give a fark and do nothing all day.
Or would it be generally younger IT personnel who just dont give a fark and do nothing all day.
Or would it be a small team of extremely over-worked individuals that are constantly putting out fires and trying to resolve the countless issues that arise?
All of the above.
I took the 33 to a shopping centre carwash when i first got it.
dude used a pressure sprayer at close range to remove a birdshit and stripped a soccerball sized bit of paint off the bonnet
That just means you had shit paint doe
  • Like 1
S13 convertible in manual. i kinda like it because its stock? maybe thats what happens when all you see are S13 drift cops anymore
http://www.carsensor.net/usedcar/detail/CU5088407384/index.html?TRCD=200002
id love a stock s13 vert with the aero kit and R33 GTR wheels= porn
also, good mate of mine stacked his car last night, after a bucks party, into a house.
f**ked the house, nothing left of the car.
i really hope he just fell asleep at the wheel and wasnt being an idiot :(
the extent of the damage though, i doubt it.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
