well its taken a month, a bunch of headaches and more questions than answers, but my telstra cable is finally setup.
comparison:
Is it worth the trouble and an extra $10 a month? if it can maintain over 10mb/s 24/7 then yes.
The provided modem/router is pretty useless... wont tell you speeds or chart usage or even let you change login username (wtf, stuck on admin forever). Now just to figure out if I can use my Fritzbox for Wifi only...
  • Like 1
On 10/7/2016 at 8:32 AM, Leroy Peterson said:
I wonder what the IT section at Telstra is like....
Would it be filled with ex-public servants who just dont give a fark and do nothing all day.
Or would it be generally younger IT personnel who just dont give a fark and do nothing all day.
Or would it be a small team of extremely over-worked individuals that are constantly putting out fires and trying to resolve the countless issues that arise?
What Department?
comparison:
This image is showing 13Mbps, not 13MBps...
8 Megabit = 1 MegaByte
The plan you are on is a 30Mbps plan and you're achieving 13Mbps.
Either there is a problem with your connection or there's congestion in your area at the time of testing... Try again later and see if it hits the full speed.
This is what a 30Mbps plan should look like:
100Mbps plan should cap out at about 115... Either way you're not likely to see the difference in the two speeds unless you download a lot of big files (not talking about torrents), or need additional upload speed (the 100Mbps plan caps out at ~2.4Mbps up instead of ~1.2)
So is this shit? Never been impressed by our internet speeds and we have had this Optus Cable for the last 6+ years.
Steam displays speeds in MBps... 2.9Mbps x 8 = 23.2Mbps = edging closer towards your 35'ish maximum.
Try http://speedof.me/ and see what result that spits out... I find its a bit more accurate, and doesn't require flash either.
Also when testing, make sure nothing else on your network is download anything... and don't be on wireless if you want an accurate result.
Blow me pat
  • Like 1
Thank f**k someone knows the difference in abbreviations
Felt like I was taking crazy pills
I mean what the shit is this Patrick
4 hours ago, Rekin said:
12.5mb/s is 100mbps - that's a good speed. Can't get faster on cable.
Getting stooged on your upload maybe? Mine is 1.15mbps on ADSL2, but only 12.5mbps download
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
