Congestion just means they don't have enough backhaul to provide the service... Modem means there's a fault and they can't provide the promised service.
Either way, you're not getting what you paid for, but it's Telstra... They used to have the monopoly on comms infrastructure... but with NBN ramping up thats going to change soon. So good luck getting them to spend money to maintain their soon to be unprofitable network.
  • Like 1
Yup and with the abandonment of Optus cable infrastructure, you will need to wait for Nbn's fibre to the curb.
http://www.gizmodo.com.au/2016/09/nbn-will-roll-fibre-to-the-curb-to-700000-homes/
However I believe Telstra cable infrastructure will be upgraded to Nbn's hybrid fibre coax
For those that don't have me on FB but want to know what Supermoto is all about made a video of the track day over the weekend :)
Basically a dirt bike with slicks or road tyres on a dirt / road track, so riding on the dirt is sketchy af and can't use any front brake.
Edited by UNR33L
Had to get puncture sorted out today, the guys that swapped tyres onto my new rims pulled out a screw that I had on a tyre, it filled it up and left it saying she'll be right, nek day take it back to get plugged.. zzz
I would of thought if I could tell something was wrong, they would be able to tell but eh.
Edited by UNR33L
88e going back down again eh
things are a bit shakey in the states, with the election and wall street scares. Couple that with british pound still on the fall, oil price retrace because some people think this OPEC agreement will achieve nothing. The other thing (which may or may not be true) is the upcoming announcement potential dates are a bit vague so people looking to jump on the bandwagon may not wanna tie up their money for potentially weeks. 88e team mentioned theyre more interested in stabilising share price than playing a game of hype and peaks/troughs.
and then theres hotcopper... where everyone is circle-jerking each other and putting themselves through financial hardship to fund "the greatest investment opportunity in all existence" while being firm that all patience pays off (regardless of how long that takes).
Yeah aussie internet really sucks dick.
Even in the middle of buttf**k nowhere when I was in Vietnam on guest wifi was getting 50mbps up / 50mbps down
#straya
Except that Australia is 23x bigger than Vietnam with 93million people vs our 20mill.
My 24 month NBN contract is about to run out. All this talk of shitty internet just reminded me I have to shop around.
All internet providers use the same cabling/infrastructure if you are in a NBN zone.
Think of isps as owning a lane on a freeway. Although a multi-lane freeway has been built, if dodo has only paid for 1-lane it will get congested at peak-hour. Whilst Telstra could have 3 lanes to itself.
So internet in Melbourne or Sydney has to be shit? I get that in the outback but doesnt need to be shit in the capitals, NBN just slow af to come
Take that argument up with your isp. Technology exists for gigabit speeds & the backhaul is built for it. Supply & demand - and the isp's have lost a chunk of their profit since they don't own the network anymore
41 minutes ago, HEKT1K said:
If you aren't a massive nerd it's fine bruz
Get over it
I'm talking more about business for productivity not home net
True, best most of our customers have is like a telstra 50/50 or 100/100 which cost em an arm and a leg
Edited by UNR33L
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
