1 hour ago, UNR33L said:
14656399_385889771798994_797822290495140
if you are  going to drive a falcon or commodore without flared guards, you have to accept you will have shitty offset on the front or ridiculous camber
No matter how hard you try, there is no option
could be worst, could be a 'stanced bro golf' :P
But yer this guy told me his rims fit, i told him no.. they dont.. he had to customize control arms and everything and they still dont fit. i think they're 10.5s or some shit on the front
Was doing some annual compliance stuff at work and in the program there is a car that for some reason represents a test on commercial property valuations... Anyway it's a fiat 500.
Was stock last year, but this year some IT nerd has stopped some TE37SL's on it.
I thought he was driving the topstage S14?
Is he driving the Team Lori Bluebird aswell?
Yep, he's a busy man.
But no offence, the bluebird is a half job because it never does more than 2 consecutive laps.
Boys and girls this is why you don't drop in a second-hand motor and hope for the best.
Number 1 conrod bearing spun and caused damage to crank. Oil pump drive also damaged.
Seller has agreed for a partial refund & the build will continue!
On 6/24/2016 at 8:03 PM, emts said:
Carpel tunnel, had surgery, tried to get back into it, on going issues could not keep going.
he was shattered.
he still turns up to some gymkanas and such
Has anyone got any recommendations now Mick has hung up the spray gun?. I want to do a windows out full car respray with my 32.
Andrew
2 minutes ago, joeyjoejoejuniorshabadoo said:
Why bother. Just spend the same amount as a new paint job on a final inspection detail every year
That's the VWL way
Needs some TLC after 10 years of track work.
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
