4 hours ago, Leroy Peterson said:
Damn, that sucks. But even if you do a basic inspection of the second hand goods you wind up like birds waiting 12months for barry
My kinder surprise was an overly shaved head that was way too high comp and some rough machining on the deck...machinist took forever to get around to it. Not at all saying my man hasn't sidelined his engine builds for drive in drive out mechanical type work, but that's been a major hold up for us. Talk is end of the year for completion so fingers crossed.
But yeah luck of the draw with second hand engines. Have to ask yourself; there's usually a reason the engine is for sale - either the car got thrashed out and trying to offload problems, a part out (why?) or stacked, in which case strong possibility of a hard life pre-stack too. Lot of shit engines out there. My seller didn't lie about having issues with the engine before I bought it - it was worth more in parts than what I paid for it, which is why I took the risk. On the bright side I got a chance to make it powerful and near bulletproof.
54 minutes ago, BBGTR said:
Has anyone got any recommendations now Mick has hung up the spray gun?. I want to do a windows out full car respray with my 32.
Andrew
I can recommend my panelbeater if you want to PM me. Just had a respray done by him and I'm very happy with the job. He does a lot of hotrods and muscle cars and those guys are pretty fussy. Very passionate about his work and it shows, but he's always got a full shop so could be a wait.
The word Bulletproof should never be written on the same page as an RB, let alone to describe an RB!
If anyone is bored, drifting live streaming from Sydney:
http://live.worldtimeattack.com/
Keiichi "Drift King" Tsuchiya says hi
5801fa05a96a2_ImageUploadedBySAUCommunit
10,000 people here. Not bad. Sydneys reputation for bogans holds true.
  • Like 2
I said bulletproof not starvation proof lol
pretty good live coverage, apart from the 10mins of ads just before
P plate Golf R gave the toot of acknowledgement after dropping behind in a rolling - is this the first non D-bag Golf owner in the history of the world?
You don't count, Hamish
  • Like 3
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
