^ whats wrong with it?
voted at council elections at 8am this morning. bloody only 3 people running. just get a committee to decide or f**king roll a dice or something. geez.
We had 20 running in Brunswick. Had to number them all too ugh
All a bunch of greenies full of hopes and dreams
lol, how to debate with a green:
"We need to battle climate change and put more money into environmental issues and open the doors for refugees"
"How you gonna pay for that?"
I never complain about eating Crab.
in fact I was planning on having some tonight.
and that was not a complaint about travel, more so about building house.
Swore no Motorsport till it done. I'm in town for deca, but only coming up to help run not enter.
that said once house done I have space for properly working on a car and can do it properly. and first time I will have all my cars in one spot for maybe 8 years!
has anyonehere built with carlisle homes? what are they like?
Im a domestic new home plumber, i do the work for 5 big name builders and then a lot of little ones,
Carlisle aren't one of them,
I haven't heard much bad about them, but i haven't heard anyone raving about them
Boutique are doing extremely well these days.
My old man is building some units in highett with leneeva homes
Carlisles structural guarantee is 10yrs
Metricon is 25
Burbank is 30
And henleys is 50!!
Metricon is 25
Burbank is 30
And henleys is 50!!
That was the most long winded way if saying "no" I have ever seen
  • Like 1
Metricon is 25
Burbank is 30
And henleys is 50!!
i was froffin the carlisle designs, dennis family homes was the gayest shit ever, its like hamish was an interior designer/builder and designed that shit, will look up burbank and henleys
  • Like 1
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
