also whats the biggest turd youve pulled out?
i want pics with a ruler and weights so i know youre not talking shit
before anyone else has the chance- "mohsens car"  "mohsens life"
New homes, no maintenance ;)
Ive been pretty lucky haven't had many bad jobs
One of the worst was trying to plunge a 3m deep sewer full of turds though..
Anyone got experience with bed bugs?
Was at a motel for 3 nights last week and have been itchy with small bites on my arms and neck for a few days now. Do they spread easy? It's hard to tell if new one have popped up over the weekend and I'm paranoid about bringing them into the house & new mattress
  • Like 1
I encountered bed bugs once.
they spread super easy so lucky I only had a small backpack as it was a overnight trip. I thew the bag in the bin
once you get them they are apparently very difficult to get rid of.
just burn down the house and start again...
http://citybugs.tamu.edu/factsheets/biting-stinging/others/ent-3012/
An exception is “Bug bombs”, or aerosol foggers. Foggers are mostly ineffective in controlling bed bugs. Because bed bugs hide in crevices and voids where aerosols do not penetrate, they are able to avoid contact with these insecticides
57 minutes ago, Birds said:
RIP new owner of Leroy's couch
Don't wanna be that guy that says I told you so, but I really enjoy being that guy.
couch was moved to the garage before I went away, so not a problem.
considering ive only got bites on my arms and neck (i assume from sleeping in a tshirt), I cant really see this turning into an infestation in my place... we shall see.
Bag got dumped in loungeroom all weekend. Didnt unpack because monday would be off again. Just removed dirty clothing to be washed then it went back in again.
Guess it doesnt matter in the end anyway, house and possessions will be getting burnt to the ground saturday morning. BYO marshmallows.
What's the difference in bites? I could be googling all this but I'm scared it's like medical results where they just state worst case scenarios. Like the time I had tonsilitis but the internet was convinced I had throat cancer.
This is a great page for images btw.
Laundramat dryers, super high heat everything.
See if you can find someone you trust to hit "Stop" and open the door after you've been in the dryer for 15 minutes... if paying a crackhead to do it, make sure you pay them AFTER they've let you out.
Learn from my mistakes, young one.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
