Scabies leave trails on your skin as they burrow and are itchy nearly 24/7. You end up with them all over your body too. Bed bugs/mites will just bite you (not sure if they lay eggs under skin like scabies?). You'll soon know either way. The hottest of hot baths doesn't kill them, only rubbing yourself with insecticide...over every square mm of your body...yes in there...will completely eliminate.
And yes old mate google the hypochondriac. Put in itchy arm bite and you get some frostbite ridden decaying limb pic. The health websites aren't much good either with their symptomatic descriptions that match up to...I don't know...f**king everything
- Headache
- Dizziness
- Nausea
- Weakness/tiredness
- Loss of appetite
My engine let go again.
Congealed exhaust gas in coolant looks like poo.
It's noticeably different from coolant and oil mixing, which I have also seen within the last 10,000kms.
  • Like 1
I think more like stock motor and never ever open the motor in any case at all.
And some responsive Borg Warner thing on the side of it.
Or who knows, maybe just put an OEM gasket back on what's currently there, unless the block is cracked or there's a portal to the underworld when they remove the head which is entirely likely.
Drove Grant's car the other day; motor felt very healthy. How is it that a guy who can't even hear his engine can keep it in better nick than you Greg :4_joy:
  • Like 2
Don't have to open the motor to put studs in.
26 minutes ago, blah_blah said:
Perhaps listen to a few of the concerns and suggestions that the engine builder had at the time when he built your motor
I have, every time which is why they were so confused when it arrived back on their doorstep yesterday..
Eliminating things that are "custom" is now my primary goal here. I wonder if things like Scotty's turbo housing/gate/manifold setup causes heat/backpressure/something (maybe it does at 400rwkw at 4000rpm....)
Perhaps the traction control system doesn't work as cleanly as advertised..
Perhaps the metal head gasket didn't seal despite the block and head being super straight and super polished by the machine shop that did it (that also built the engine)
Perhaps the 'custom pistons' that were ordered and sized up for the kit way way back when by someone who was grossly incompetent is causing these fun and games too..
But power was turned down to about 320kw. Given I was pretty happy with that, a standard Neo will be finding its way to that engine bay because I'm really not a fan of "perhaps" (even if something becomes immediately clear as the problem, like last time).
I believe this was brought up as a concern when your engine was built :1310_thumbsup_tone1:
I've had my engine for 3.5 years now and still going strong, only issue was a blocked injector due to e85.
Internally your engine and mine probably same same except for the 2.8 stroker
It was, because back then I had a GTX3076R then with a .82 rear, I took the recommendation and went with a much larger rear to open the whole thing up. Also opened up the intake which would have been contributing to that problem (and picked up 45rwkw lol). But it's possible that the damage had been done, but seeing an engine roll over up top, or an exhaust housing go slightly red doesn't usually result in a blown head gasket. I have never actually run the GTX3076R for longer than about an hour before I changed to a free flowing rear.
And since then the head was lifting under boost (wrong head studs supplied way back then, and re-used by current builder because "ARP studs are reusable". This was discovered when I bought a new gasket and studs because I didn't trust the internet when they said you can re-use metal head gaskets and ARP studs.
And what do you know, the old ones were about 25mm bigger.
Then the block cracked literally 2 days after that was assembled, full rebuild since then, with all the recommendations made, followed.
I directly followed recommendations of people around me... because when you have problems you start looking at people who do not have problems to see where the differences lie...
As to what failed this time, no one is sure yet, other than it's exhaust gases in the coolant.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
