1 hour ago, blah_blah said:
Those who have brought aftermarket diff's Kaaz or Nismo
Where did you guys end up sourcing it from?
Nismo cheapest i can find is RHDjapan
Kaaz only from MD spares in Aus
weld the f**k out of it
Moh how long you going to USA for?
have you got a "Don't shoot I'm not black" tshirt
if there on the 9th Nov remember to have a oh crap Trump got in/didn't get in anti riot kit.
If I was a visitor there not sure which would be worse, trump supporters celebrating or protesting..either thing will involve guns.
I got my KAAZ centre from eBay
Such a beautifully predictable diff
Speaking of, aside from the loud road noise, I can't speak highly enough of the Federal RS-RRs as a bargain tyre. They are definitely soft; already got some burnt rubber near the edge of the side walls after some spirited laps through the mountains, but the grip on hand from a $180 tyre even on the smaller 245 tread is sensational. Left a knee down 600cc bike for dead on Sat...he wasn't slow! Really like to try these at the track.
  • Like 1
Talking to richo he agreed...untill you some proper heat cycles then they go off, just like the old ones.
SO great for street as they don't get to track temps. but not so good.
what they have been testing out on the BMW was the nagkang NS-2R and having great results at 140 a tyre, (think R888 quality not A050)
http://nankangtyres.com.au/tyre/ns-2r/
going to grab some when back on track.
Might try them next, particularly if they are quieter than the Federals, but I think at beginner speeds/laps I wouldn't be unhappy if these only lasted me a couple of track days and 5000-10,000km of street driving. We shall see.
Also loving my Shockworks coilovers, which in spite of feeling firmer, dispense bumps in the road much more predictably than my previous setup when pushing it.
$1.4k off ebay for a Kaaz
$1.1k for a nismo from japan + shipping + GST
I remember Kaaz used to be a fair bit cheaper
I paid about 950 from memory, perhaps 6 years ago? That was a trade price, from Jackie Chan / CP motor or whatever, and for the 1.5 way.
I've heard nismo and KAAZ are much the same centre. Perhaps as KAAZ built a name for themselves, like Kumho tyres they got more expensive?
17 minutes ago, admS15 said:
Try Jesse Streeter
Yeah about $1.3k through Jesse for a Nismo
You work for a place that rebuilds stuff like diffs right? Same same to repair a kaaz and nismo? Heard sourcing and replacing parts for Kaaz would be alot easier
ill be leaving the US on the 10th lol
Used to...we didn't do many rebuilds of clutch pack LSDs, just your average Commy/Falcon shim job. If you're talking clutch packs then the KAAZ should be cheaper to source parts for. Again, they may use the same parts as the Nismo? They last a long time though. No rebuild for me yet; I do change the diff oil often though (every 10,000km or so).
  • Like 1
24 minutes ago, UNR33L said:
nah m8 ford 9inch diff m8
Used to do a lot of these conversions
We had bolt on solutions at one stage, axles disc brakes calipers and all. Just unbolt the rear and install.
From what I've seen it's the "tolerant" left more inclined to be violent in their protesting
What a load of "poor-me" conservative facebook comment section horse shit.
Let me guess, the left media is opressing you too by holding back the silent majority?
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
