2 hours ago, alr33x said:
an investment that turned out very nicely for the buyer.. geez you lot hold on to stuff way to long its actually kind of sad.
good work on ya dollarmite account :)
Was the buyer Chinese? Just a hunch
1 hour ago, emts said:
western Suburbs so doubt it.
Martin thought of you the other day (nohomo) the bathurst conrod straight house / land is for sale (2mill approx they reckon)
Also Birds, Taha is going back to prison again :(
Want to take pulsar to Gibson motorsport tomorrow.... Anyone wanna play with the autronic while I drive it around the block tonight? lol
I haven't driven it since leaving the shop 2 weeks ago, but once it was fully warmed up from 5mins on the street it's like high load at low rpm, foot down, no accelerator passed ~10% throttle. TPS reads fine, there is a rev cut at below 40° coolant temp, but I just checked the ecu is reading coolant temp fine.
Not being able to take off at a set of lights makes it pretty much undriveable once I get around the corner.
  • Like 1
Serious? I saw him at mens gallery like two months ago, he neglected to mention that lol...though he was driving a Lambo around so, kind of adds up...
Yeh I got him on facebook lel
Add $250 water bill to that list of bills I have right now, fml :( #adultlyfe
Edited by UNR33L
Took car for a drive, coolant temps are pretty damn low when putting around off boost. Started to cut out again, so turned off the low-temp rev limiter and it cleared it all up. Needs a bit of tidying up at higher rpm but success!
Hooooly shit it's the loudest turbo sounded car I've ever been in. Maybe it's the vented bonnet and small open gateway between cabin and engine bay.
Inb4 car destroyed due to Greg-style tampering.
  • Like 2
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
