On 11/18/2016 at 9:19 PM, Birds said:
strong fridge game /10
18 hours ago, Birds said:
rip
17 hours ago, Rekin said:
Since when did I mess up a build, my rb20 was on point.
till she blew
don't garrett have new 30/35 series turbos? put a 35something on it m8
Also a guy with a new 2016 macbook pro (only comes with 2 USB TYPE C ports and that's it) buys micro SD card adapter to usb C to get some of his data off it, proceeds to snap his SD card in half trying to put it in this adapter thing, f*kn loled so hard
On 18/11/2016 at 4:17 PM, Leroy Peterson said:
Want to take pulsar to Gibson motorsport tomorrow.... Anyone wanna play with the autronic while I drive it around the block tonight? lol
I haven't driven it since leaving the shop 2 weeks ago, but once it was fully warmed up from 5mins on the street it's like high load at low rpm, foot down, no accelerator passed ~10% throttle. TPS reads fine, there is a rev cut at below 40° coolant temp, but I just checked the ecu is reading coolant temp fine.
Not being able to take off at a set of lights makes it pretty much undriveable once I get around the corner.
After seeing Gibson Motorsport sport over the weekend I might get them to install the new box.
Im running a Autronic also, very happy with it
Yeah even when my brother had a 3076 on his rb25 was pretty bad, no power then hits boost and spins it up too hard.
Speaking of which, that 33 is just rotting on the side of parents house :( so sad even has decent Advan TC3 rims on it :\
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
