Vic Wasteland Thread - 15.0
R31Nismoid
 Share
My mates use the roulette table to pregame in vegas.
one drops 5$ on red every spin the other black, split the difference at end of night and as much free booze as they can drink
5$ each every 37 spins on average aint bad for booze.
  • Like 1
thats the most australian thing ive ever read lol.
also, f**k were lucky to be strayans,
USA is a proper shithole
  • Like 1
had no money on alvarez. just for anybody KO. If McGregor went on to fight Khabib (doubt it), i would seriously want Khabib to win. He probably couldnt take a left to the face, but if he's smart and doesnt play the boxing game, McG would be in a very tough spot on the ground. The Russian is crazy strong on the ground. Would be a great fight.
Also had money on Kovalev over the weekend. dominated the first rounds, then dropped off a bit, but Ward dominated the scoring. f**kin rigged bro.
If I ever wrote off mine and had the option to buy it back half cheap I probably would to part out / sell as is at a profit
Pretty expensive engines
Edited by UNR33L
15 hours ago, Birds said:
I think it's no coincidence Leroy put his money on Hillary, Alvarez and Pulsars
Someone needs to start working a little harder or thinking a little smarter...
Edited by Daz
  • Like 1
Nah he just needs to put it all on 88e :D
  • Like 1
I'll be the first to admit:
There is profit to be made betting against every match I place a bet on.
I put a lot of research into most of the UFC 205 fights. Barely broke even. Some surprises for sure. But that seems to be the way with any unorthodox money making... It's all timing and luck.
Thomas Jefferson said the harder he worked the luckier he got. But trust an American president to say that shit.
When I used to use sportsbet, years ago and muck around with about $100 a year, there was a point where I was betting on surfing...actually trusting waves to deliver me wins. At that point I stopped...
  • Like 1
You only made .1 cents?
Currently on-site waiting for server data to copy from old-new hardware zzzzz waiting for that loading bar. #itlyfe
Will still be an hour or so I reckon :(
Edited by UNR33L
 Share
    • Wait, the flappy paddles or sequential is the small penis indicator?  Either way, I can't afford it.
    • You and me both. If I ever get it running again, I'll have to look into cruise control.
    • Yeah most people that have heard it said it was fine but it's always had me slightly worried. Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60 You're probably right mate, best get ordering some shims! Guessing Nissan is the best place for them?
    • Just wanna preface this and point out I'm a mechanical fitter by trade but have had very little rebuild/machining experience, but I am keen to learn, hence this project. Bit of a write up here so bear with me, just want to make sure I do this right  I've got an rb30e currently pulled down. Planning on putting a 25 head on it and running it in my s14.  Not chasing huge power so I'm just going to try get away with factory bottom end for now.  Started measuring the crank the other day, realised my budget daytona micrometer set wasn't up to the task (surprise, I know). They only measure to 0.01mm but the Nissan specs are to 0.001mm. Anyway, I started measuring anyway and came away with the mains being inline with the oem spec, as well as the big ends, except for no. 5. I consistently got a measurement of a hair over 49.96mm, where all the others were pretty spot on 49.97mm. The lower spec for grade no.1 is 49.961mm. I'm getting access to some better gear my next days off to double check everything, but in the case that the big end is right on that bottom spec, is it pretty much just a case of straight to the machine shop for machining and oversized bearings? I understand I need to measure the tunnel as well to work out my oil clearance, but it's the different grade bearings in the manual that are confusing me. What is generally the process when one journal would still technically be in spec, but in a different grade?  Thanks for coming to my Ted talk
    • You need to visit Ipswich. Plenty of clapped out R32 and R33s running around here as daily drivers. And when I say clapped out, they're how you'd look at a VN, when it's the year 2010...
