2 hours ago, UNR33L said:
You only made .1 cents?
Currently on-site waiting for server data to copy from old-new hardware zzzzz waiting for that loading bar. #itlyfe
Will still be an hour or so I reckon :(
Yeah...but I did it 155,000 times over (tired from all the clicking), so minus $40 brokerage...pocket maybe $120? Alright for 10 mins work! The streak has to end soon surely...
2 hours ago, emts said:
how much data?
Spent this morning trying to get 10Gig off a box with only a 1Mbit interface.
ouch, was only about 150GB took about 2 hours to finish it tonight total
2 minutes ago, emts said:
well it not really 10 min work.
Add in all the time you spend monitoring to this and what does that hourly rate turn into?
the man has a point, just put 10k on red and be done with it
on another note, toying the idea of owning a falcon turbo ute, stupid I know being an IT guy for work.. but dat space for motorbikes in the back and getting in a 4lt turbo could be fun.. right?
Edited by UNR33L
Yeah I saw how long mine was and set up a script to run in the background
should be done by morning.
moved on to other work
that one going from a 10+ year old Solaris crappy machine to a nice new Linux VM.
Nah 10 minutes
Sell order gets placed the moment the stock is bought
All I do is glance at the orders list to see if it's gone through; might watch a morning auction out of interest
10k on red = 52% chance of losing 100% of it
Get a bad spin on a daytrade and most of the time you can wait for your money to return or pull out with about 95% of it
So deca results, 19th out of 46 aint too bad considering it's a automatic boat and the afternoon battles mostly burnout time :P
As long as I beat 3 out of 4 of the new mustangs
Edited by UNR33L
Why are you worried about what people think about what you drive for your job?
Just tell people you need more space to carry computers.
I'm not worried, you guys were meant to talk me out of it :P
6 minutes ago, emts said:
yeah as no IT guy would drive a ute...
Why have you got one anyway? Car parts? :D
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
