24 minutes ago, emts said:
Mainly as I'm a country red neck.
Fair enough, if I got one would have to be 2nd car.. couldn't 'downgrade' the current car for one :\ 2 car regos can fek right off though
Edited by UNR33L
Anyone know anyone who's got a RB25/Neo block laying around? As I am now onto my 4th and sleeves don't seem to readily exist because "What exactly would you sleeve it with that's stronger?"
(yes I shall turn down the powers)
http://www.ebay.com.au/itm/Ford-Coyote-Miami-5ltr-Supercharged-FPV-GT-Engine-740HP-/122190780243?hash=item1c73235753:g:c3EAAOSw-CpYBsAa
:D
Nah but serious, I'll ask my brother what he is doing with his.. his 33 has been sitting on the side of the house for about 3 years
Edited by UNR33L
  • Like 1
[emoji32]
Time for billet block
1 hour ago, Leroy Peterson said:
Tis the GTR way
Then once thats done, you just spend your days trawling for Nismo "bargains"
Omg Nismo key for $500
[emoji32]
i got one but its probably no good
12 hours ago, joeyjoejoejuniorshabadoo said:
Built RB'S are the single biggest waste of time, effort and cash in the car scene.
i wouldnt expect a GTST owner to know.
WOW I FEEL LIKE I NEED TO HAVE A SHOWER AFTER SAYING THAT
  • Like 2
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
