so after switching to Telstra a few months ago, I get a letter in the mail last week saying NBN is now available in my area... before I made the switch the NBN website indicated it was not in its soon-planned areas. Doesnt really matter because Internode isnt listed on the providers list anyway. Am happy with the cable currently so will stick with it.
Yeah I got a NBN letter too from internode.. yet I go and check the NBN site and same thing, no progress or any info - pretty pointless site I guess, kinda. Pat fix it :)
Currently fixing my bill with Telstra online chat after changing plans.. ofcourse my next bill was all f**ked up but I expected that..
Must be hard to run a competent ISP
Edited by UNR33L
ipvanish will work a treat on NBN, hotels, airport lounges maccas Mc WiFI the works.
I'm moving to that when we finish the house.
the above was just on the phone as wanted to check some speeds.
Telstra online chat has been my go-to for dealing with (numerous) issues. I can do other shit while I wait for a response and can hear when they respond. It takes a few bots/foreigners to get through to someone who can help but soooo much easier than the phone or going to a store.
Am currently on my 3rd debit card in under 5 years. The insert chips all die within 18 months. Then you gotta do the stupid dance of insert, fail, swipe, insert, fail, swipe etc.
Anyone else here have/had issues? excessive heat maybe? I thought maybe electromagnetic fields, but the swipe strip is fine.
3 hours ago, dezz said:
Any downside to nbn like the government knowing what genre of porn I may or may not be watching? Will ipvanish etc still do its job on nbn?
Exactly what I'm afraid of in a few years, government seeing everything nek minit in court for all the piracy n shit.
When I worked at a small ISP we'd get warnings all the time from all the big movie makers and have to give the customer a warning, I've been downloading movies with Telstra for 15 years never once received a letter.. clearly they just don't give a f**k. I dunno about the government though?
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
