9 hours ago, UNR33L said:
Exactly what I'm afraid of in a few years, government seeing everything nek minit in court for all the piracy n shit.
When I worked at a small ISP we'd get warnings all the time from all the big movie makers and have to give the customer a warning, I've been downloading movies with Telstra for 15 years never once received a letter.. clearly they just don't give a f**k. I dunno about the government though?
Had NBN for over 2yrs. never received a letter.
1 hour ago, Leroy Peterson said:
Only works for sub-$100 transactions. I thought y'all were VWLBC?
Plus I try to avoid the few days it takes to process those transactions if possible.
You can use above $100 just have to enter pin like you would inserting it
Process delay is annoying but I think if you've entered pin it should go through straight away like inserting
Works over $100 just need to enter your pin after tapping
I've got a ME bank debit card I use once a week with a tap, and if I use it every week once I get a free village movie voucher at the end of the month it's pretty rad considering movies cost a fortune these days to go and see :)
Edited by UNR33L
I did not know this. Interesting.
Apparently america is transitioning to PINs only and everyone is chucking the shits. VISA insisting on signing because they dont think people will be capable of remembering their 4-digit code. lol. And walmart is suing them for it. lolz.
I just use the same pin for all my cards, probably not best practice but at least I can remember it.
88e on it's way up, I predict 50 cents by end of today
Edited by UNR33L
If you put that on HC you would have won post if the day and become a valuable member with 1 post then everyone would follow your shares portfolio for inspiration.
  • Like 1
1 hour ago, Spressy said:
not trying to be a nuisance, but what's the reasoning with cash only?
In the case of Mohsen it's to eliminate any paper trails thereby voiding his avenues of recourse when he inevitably pays for defective defective goods and services
4 hours ago, joeyjoejoejuniorshabadoo said:
Apple pay allows over $100 as it's thumb print ID'd
Hippy
If some guy was paying for his petrol and fumbling his phone around trying to unlock his phone and find the app I'd be forced to jump kick him out of my way
But srs, yeah in 5 years we wont even have a wallet
Edited by UNR33L
Double-click the home button from standby mode, it opens and confirms fingerprint instantly. It's quicker than a physical card.
I'm paid and out of the store while you're still standing there touching yourself over some lame android feature you will never need.
Fk if I could be bothered digging up posts of you slamming Apple and fanboiing android phones
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
