So Knox police putting a stop to SNL... no more BP Eastlink. theres talk of safety hazard backing up the freeway with people trying to get in. i kind of understand it... but its hardly co-operating with the organisers (though I guess its not technically a legal meet, especially when you got 500 cars showing up)
Unwatchable! Totally biased, not funny and the meet point just can't get any worse. Sad
  • Like 1
It would be interesting to see how they could legally enforce this, short of defecting everyone. Technically it's just a random bunch of cars parking in a car park that is private property (I imagine, owned or rented by the service station?). What's illegal about that? Maybe they should wait until something actually happens.
I mean, if they are worried about traffic banking up because of a meet...have they driven on the Monash in the last 15 years?
The better was at Daniels Donuts, which is a 24 hour Donut/Pie shop which is in a little "shopping centre" with a massive shared car park which is outdoors and open 24/7.
Apparently police came and shooed everyone away, when they were legitimately buying food from a place that is open 24 hours, none of the other shops in that area were open.
Telling them to move on from a legal parking spot trying to legally buy food from an open business serving them? Pretty lolsy.
Maybe go to the one on the otherside? lol id be surprised if they had staff at both approaching any car thats cleaner than most others.
BP eastlink doesnt sell kebabs so im happy to find somewhere else to stand around. Was standing around with VIP people at bottom of olivers hill jetty last weekend and had some dude in the wrangler drive passed slowly and call us gayflamin mongrels. (Mind you one of the guys had a drift RC car)
I got an rx7 rc drift car I bought ages ago with Bez when we thought it was a good idea.
Actually had a fair bit of fun out of it too bad sits in the cupboard now days with some battle scars haha.
Gayflamin mongrel
  • Like 1
So got a notice to vacate current rental as they have decided to sell, and there be a couple months cross over from this place to the new house finished.
thinking finding a short term renal plus moving stuff multiple times is too much a PITA
So thinking put stuff in storage and use the rent money for new furniture.
1 hour ago, Down_Shift said:
Same here Leigh!
And it's only been day 4 of unemployment.
IT life hey, (you were i.t right?)
Martin that sucks, worst timing for you - move stuff to your new property lock it up and stay at a cheap hotel for a few weeks?
Actually lets all stay at Pats place
Edited by UNR33L
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
