not sure it a secret
Nah
Mine is a 26/30
He did tell me about that one though
Dropped in on him today to give him a push, fkin busier than ever. If you say tall guy from the east with the blonde gf he'll know who you're talking about...
I don't care about the top end just yet and the car came with GT-SS...a top end that dies off at 400awkw is still a fast car. Is it fast enough so we can fly away? I don't know.
Everyone goes for 11ty unusable gearbox breaking kw in their GTR...rather do something cheaper, different and friendlier for the street. Acceleration in any gear at any rpm, that's the plan.
Tbh my car fell apart with a GTX3076R which maxes out at 400rwkw (on manual) because it was too responsive. Having to set a rev limit at 5900 rpm is kind of lol.
Would suspect same issue with GTSS-s and a RB30, but maybe not. You gotta give it a go, and the turbos are already with the car so f**kit why not?
I had other issues relating to dat dere 14s pass :P
It's just a preference i hold for runing through revs.
For example, I preferred my car to Al's. Both 330rwkw but his was on it by 2k and over by 6k whereas mine was 3k to 7.5k
Both massive fun... very different animals though
And yours is only a 2.8L as well!
I thought it reached max power well before 5.9k rpm?
For example, I preferred my car to Al's. Both 330hub kw but his was on it by 2k and over by 6k whereas mine was 3k to 7.5k
fyp
Edited by UNR33L
Swapping down the track isn't too difficult...GT-SS hold their value well and usually worth a little more than -5, so I'm looking at the cost of a turbo swap and a retune for bigger turbos if I want more power. I love my responsive GTS-T though and would want a similar set up in the R.
Only need to put low boost through a 30 to get big numbers, plus it'll be E85 after the 98 tune.
You really think youll hit 400awkw? Thats more than just a decent motor to get that far
Barry believes it, with E85. RB26s with 98 make about 340-350 with GT-SS.
have you driven a 3.0 RB?
the difference the displacement makes is a lot more than you would expect.
it should be a fair whack more responsive than your gtst
Al's car is like a freaking V8
Interesting
Steve 34R aka R8TED only made 317kw on the racepace dyno on e85 and -9's. Not sure what the norm is, maybe Matt Borci will throw in his 2 cents
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
    • I clean my wheels every time I wash the car, I also clean the barrels, the only product I use on the wheels is truck wash and a pressure washer, followed by (inset your chosen name brand) wash and wax, time per wheel is probably 2 minutes total, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, they're also great for getting in between the front guards and body, and tight spots in the engine bay
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
