1 hour ago, joeyjoejoejuniorshabadoo said:
Added "senior" to my title today
A way of giving you a promotion without giving you one?
Did it at least come with a pay rise?
Congrats brah
11 minutes ago, Leroy Peterson said:
I hope to get Senior title when I hit 10 years in the industry... 2 or so years to go. Then hopefully people will take my resume seriously ffs
Just add it now anyway.
When I was 17 I was the product relocation specialist for the largest supermarket brand in Australiasia
The RB26 tax on that build was unreal. Two in a row asking for 28-30k for an engine.
Maybe I'll put 26 rocker covers on it and up the price by 15K. Throw in some free VCT or something.
Congrats brah
Nah, it's a proper gig. moving to Camberwell Business Banking Centre too.
They came to the table financially, but I took the job on the provision that I move upwards when the next opportunity is there so that's the real motivation
  • Like 1
I want to get out of technical work and go into an I.T PM role before becoming a 'senior' don't think I've got it in me to continue down the tech path forever.
No one wants to listen to a 27 y/o boss them around though, I still gotta do some courses too to get in the door
Just add it anyway, what's stopping you?
My boss, because he charges me out to my job title.
When I first started in small business I was barely 6 months out of my time, so added a junior title, boss said get rid of it or clients will think they should pay discounted for a "junior"
To start with you would look like a jackass who thinks they are better than their Peers.
Better to go to the boss direct discuss your reason for being promoted and if there things still to cover off build a plan to get there.
that said if your going to lie on your signature why stop at just Snr might as well go CTO or similar.
Be your own boss, grow some balls
23 minutes ago, Leroy Peterson said:
Lol
You have no idea.
Sorry to have misled you with the impression you were going to gain sound career advice from myself or VWL in general
  • Like 3
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
