I want to get out of technical work and go into an I.T PM role before becoming a 'senior' don't think I've got it in me to continue down the tech path forever.
No one wants to listen to a 27 y/o boss them around though, I still gotta do some courses too to get in the door
Anyone can warm a seat for 10-20yrs and claim it as 'experience', it's what you achieve in that time which counts. You could achieve more in 5yrs than someone who ticks-thru 20yrs.
If your time spent has provided you the capability to perform the role don't write it off due to a number, be it age or #yrs working.
If you can prove your worth now to your direct-reports rather than falling back on what you did in the past, you will come out with respect no matter of your age.
  • Like 3
Try telling that to HR who filter the applications and weed out the ones who don't "meet" the requirements.
Or trying to get through recruitment agency word search filters.
All of whom don't give a f**k about references or achievements or milestones.
  • Like 1
Cover letter most important^
If you quantify in words your experience due to the quality of your work and level of involvement, you'll easily shoot over someone who says they've been in the game for 10 years but can't put into words what that means because they've warmed a seat and never done anything exceptional. Time of experience is also easy to lie about and good HR managers know this.
Time is also generally correlated with experience even if there are outliers like go getters and seat warmers, so you need inventive ways to be considered over the others.
Also, sif work for a company that purely values quantitative experience over quality...that's a sure way for your hard work to result in someone else's promotion because they're "overdue" for it / are next in line...consider their filtration of you a filtration of them too.
  • Like 2
True that, it's more me not getting off my ass and doing a course or doing something different to side step down the management path rather than technical.
Plan has always been do technical stuff till about 30 so I've got a solid 10 years experience then re-evaluate what I wanna do in my 30s career wise.
I know I'm listing numbers but I dunno, in IT seems like everything changed once I had 5 years experience under my belt, that could just be like you said by achieving more in that time than others with 20 yrs experience.. man some of these old guys have NFI how shit works..
Edited by UNR33L
12 minutes ago, Leroy Peterson said:
1999? I remember that thing.
The Matrix, Y2K, Red Hot Chili Peppers.
pls
The matrix confirmed the year was 2199 and 1999 was simply a construct of the machines, Y2k was in 2000 and the Chilli Peppers peaked in 1991 with the release of Blood Sugar Sex Magic
1999 was all about Futurama
26 minutes ago, joeyjoejoejuniorshabadoo said:
pls
And Hard Kandy
Just got a gas bill more than 3x of any bill in the last 12months, the charges go all the way to step-3 off peak.
Only gas appliances are heater and hot water. Heater is disconnected electrically and was serviced in winter. I was away from home 4 nights a week from Jan to Feb, then overseas for a month.
I'm reading that sometimes gas companies to 'catch-up' bills if they get their estimation wrong?
I'll check the gas meter when I get home, but if the figures are similar, ain't shit I can do?
Went from 27MJ a day to 147MJ a day. No leaks that I know of...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
