yeah they do an estimate based on previous usage every 3 months, only do a real check every 12 months or so and then do a top up.
I had the opposite in the past when I started traveling for work, usage dropped massively and ended up with a decent credit.
2 hours ago, HEKT1K said:
Went to a travel agent for the first time today, to see if I was missing out on the best deals etc
Travel agent: "Where's Skopje?"
nope
And when you been waiting and do a follow up with them forgetting to call you back with their deals.... "I forgot"
Just got a gas bill more than 3x of any bill in the last 12months, the charges go all the way to step-3 off peak.
Only gas appliances are heater and hot water. Heater is disconnected electrically and was serviced in winter. I was away from home 4 nights a week from Jan to Feb, then overseas for a month.
I'm reading that sometimes gas companies to 'catch-up' bills if they get their estimation wrong?
I'll check the gas meter when I get home, but if the figures are similar, ain't shit I can do?
Went from 27MJ a day to 147MJ a day. No leaks that I know of...
Old man had the same issue where his bill tripled in one month. He just didn't pay it until they came out and did a reading. Turns out they got their measurement units confused and over calculated it.
36 minutes ago, Mohsen said:
also how the f**k do i set up boost Ts?
you need a boost gauge.
cut your actuator vacc line in half. put boost tee on eitherside of cut vacc line. Set to like 1-2 turns off lowest setting. drive. note down boost. adjust accordingly.
44 minutes ago, Mohsen said:
boys boys boys.
whos got a metal intake pipe to suit rb25 laying around? trying to get the stag to rip massive VL spec doses lmao
Got one here if you want to buy.
3 hours ago, Mohsen said:
boys boys boys.
does anyone in this forum have anything to do with cars these days?
its only you and hamo who dont do cars no more.
I commented on something on facebook and the notorious Krysztof got butthurt. Am I getting him confused with that guy that is a living punchline in VWL?
done. 30psi TONIGHT
the question is, will it flutter like central park does if you walk through it with some bread?
how much. will pay top dollar for something dodgy as f**k.
a few of us still do, but it feels like were all in exile.
maybe one day we will unite and power will be restored.
  • Like 1
4 hours ago, Mohsen said:
boys boys boys.
Use K&H bumper black spray (the one for 80's black bumpers) and it looks like a stock part works a treat
  • Like 1
I might when the Kia Stinger GT is released as that think will need maybe exhaust/boost/tune
totally getting me one
yeah i saw some photos of them they look pretty decent actually
im thinking of upgrading but then i feel its a waste of money so meh.. probably gonna end up buying something lol
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
