34 minutes ago, Mohsen said:
the question is, will it flutter like central park does if you walk through it with some bread?
how much. will pay top dollar for something dodgy as f**k.
$80 and a reach around to make you flutter like a little girl tonight.
yeah, I'm not prepared to novate over 3 years due to the massive baloon and I'm not prepared to have a decent euro (not including the train tation hack golf I currently have before anyone points this out) non under warranty
yeah agree no warranty wouldnt touch a euro. Biggest mistake people make is buying a second hand euro which has depreciated a heap but they forget the repairs / maintenance / parts are priced according to original price..
Edited by alr33x
* and designed to fail
I've always been pro Aussie, but after driving a brand new Territory with interior ergonomics and design that hasn't changed since the 00s and buttons that feel like they were supplied by Fisher Price, I'd be steering clear of a Ford at least.
Actually, even new Subaru Foresters feel junky as f**k. Maybe new cars on the whole are sucking a dick.
I like to live dangerously
  • Like 1
Yeah they're still based on the 08 FG, same as my 2011 although mines got some FPV adjustments & improvements.
I still rate mine better than the 2015 STI I drove in almost all areas beside the seat / satnav. Camera + climate control of the Ford shat on the STI
Oh the STI had a nicer steering wheel too.. felt like a Prius power wise though, WRX > STI engine
Edited by UNR33L
you need a boost gauge.
cut your actuator vacc line in half. put boost tee on eitherside of cut vacc line. Set to like 1-2 turns off lowest setting. drive. note down boost. adjust accordingly.
Who gives legitimately useful advice in a wasteland thread.
Wtf man.
  • Like 2
My ford's interior all feels pretty nice.
It's a euro built one though. Most of the Aussie ones are built in Thailand where a fewer number of f**ks are given to quality as long as it's cheap.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
