250HP at wheels from APR site...not KW.
Edit: yes this is a GTI but they claim the same for all the E888 motors so the R S3 blah blah whatevers
That's not a mk7 and the R and gti are not the same motor. The R has a much larger turbo.
With the correct graph, Apr state 354hp at the wheels for the mk7 r (264kw)
Is it possible to retrieve data from the SSD? backed up the SATA drive with the dock, if I can back up the SSD I'll be set..
After that, will doing a fresh install of windows solve my boot issue, or am I gonna have to take it back to centre com?
My prediction of 88E falling post spud (a nothing event) came true
But I did not predict a small spike occurring today over a nothing update from DW essentially saying "everything is going fine"
The short term reactions to long term investments never cease to amaze me. The buyer behavioir in a nutshell is "everything went as expected in the day to day operations of a company today, time for me to buy in".
14 minutes ago, Leroy Peterson said:
hey Leigh, I have one these lying around if you want it cheep for one of your many motorbikes.
https://ecliptech.com.au/shift-i/
No need brah I got one of these bad boys laying around too
https://www.mxstore.com.au/p/Trail-Tech-Suzuki-DRZ-RMZ-250-450-Silver-Vapor-Com/75-301?gclid=CjwKEAjw3KDIBRCz0KvZlJ7k4TgSJABDqOK71ezh5hqTPUGrwJC3S8UyMNZoUCoNCzm7o7_rqEGYQBoCCx3w_wcB
If shares were easy to predict everyone would be a millionaire
how do you install it?
my current shift light is not giving me much joy
If everyone were a millionaire our dollar would be so inflated that your Falcon would be worth a few mil.
Reactions are usually easy to predict, events not so. Knowing the former can give you a bit of an advantage.
Brah call MSI tech support, sounds pretty bricked if you can't get into BIOS. Probably needs a motherboard replacement done by one of their techs.
Or if you are baller enough just buy a freshie, get your MSI one fixed then sell it when you get it back.
Ric must be a real POS - how often you actually use it? :P don't you get a laptop through work anyway?
Not often lol, it's pretty clunky but does the job
I have an X1 Carbon for work
1 hour ago, dezz said:
Yeah I'll call em just wanna back everything up first if they're gonna wipe it in the process..
Any way to backup the SSD?
If it's physically removable then yeah you can put it in a caddy / usb cable and grab your stuff.
If it's part of your motherboard soldered on then nope (MSI probably have ways though) (or if it would actually boot you can run software off a USB to clone the disk.. but yours won't boot so yeah..)
Edited by UNR33L
/remove home made porn before someone else sees it
That stuff is stored on a separate drive
Is that another dock I need, or are they the same pin set up as a normal hard drive...?
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
