5 hours ago, emts said:
how do you install it?
my current shift light is not giving me much joy
its like power/neg/rpm signal.
Not hard. pulsar was not a typical setup, so i never got it running, but someone else with a pulsar did. i dunno. I dont need it anymore. so its $40 if you want it. Got manual and box for it, maybe 30cm of wire and its the flat type, not the curved type. its quite a good unit. can set custom rpm increments and will use lights to show battery voltage when on Acc.
Also f**k this hotel internet. uses a Mikrotik router of some sort... using a release from 2015 so it cant be that old... repeated speedtests says everything is fine, pulls decent speed, but every 10mins or so it just wont load webpages. I had a download running and it was stable at 200kbs, then spiked to 1000. all the while google would time out. Owner says the router cuts you off if you breach 500mb in an hour, but i can barely use it for 5mins without problems.
1 hour ago, dezz said:
That stuff is stored on a separate drive
Is that another dock I need, or are they the same pin set up as a normal hard drive...?
depends on what SSD you have, the normal "sata" ones are same pin setup as hard drives though yes.
On 5/2/2017 at 1:08 AM, Birds said:
Got a source for RS6 quartermile times? That sounds optimistic to me for the V10 model. Regardless, none of that negates my point that the same results can be achieved for substantially less in a probably more reliable and cheaper to repair way.
Also struggling with 12 second flat from R/S3 with just that. I'd believe breaking into the 12s...but am feeling a turbo swap to get a high 11 out of them. They would need another 100kw at least...
High 11's is doable with EA888 MQB platform motors, EA113 like mine, I reckon it isn't possible, but could be wrong... One way to find out hey?
On 5/2/2017 at 9:43 AM, Birds said:
Wow if that is the stock turbo...are they laggy or just amazing tech?
F6 seems to do similar stuff with flash tune and exhaust
I imagine life gets very expensive once you go beyond that for the Golf
Stage 1, 2 are with stock turbo. Upgraded turbo is considered stage 3. Poofy I know. If you see people with MK5 GTI or MK6R with a "+" that means high pressure fuel pump upgrade on top of the tune.
On 5/2/2017 at 11:27 AM, blah_blah said:
So what power does a stock Golf R make?
And what power does one with a tune, exhaust and cooler make and cost?
Damn so many golfs on the street these days they will just cream me i spose lol
Ive been in a launched Golf R and it was quick from a launch but died down afterwards
At wheels, 165-170kw (at least with MK6 - dunno about MK7)
On 5/2/2017 at 11:29 AM, TiTAN said:
They are a big stock turbo compared to what they tune it to. In "stage 2" trim you are around 250kw at the wheels. So it doesn't really hit hard until 3000-3500.
Yep, Golf R has K04 from factory (at least with MK6), 250 is pushing it, I'd say 230-240 at wheels with 2+ (plus intercooler, DV, and maybe actuator).
On 5/2/2017 at 11:40 AM, blah_blah said:
250awkw with a cooler zort and tune wow. How does the DSG hold up
Should have bought the wife a Golf R not an Evo X
Apparently the stock clutch packs in 6 speed DSG as found in GTI/R/GTD/TDI can handle 600 crank HP.
As for daily driving, DSG is brilliant. Drives like a auto and will do compression braking if you're driving steep hill downwards. Although DSG reprogram would be ideal, its bit "lazy" when you want to do overtakes or something.
I should make mine faster and that means $$$$
On 5/2/2017 at 11:50 AM, TiTAN said:
Not sure about the dsg, the dry clutch 7 speed boxes aren't known for their reliability but the 6 speed wet clutches seem to go ok, but I'm not sure how they go at that power level.
Read above. And mine has done nearly 142k kms (I drive it every day) and it's faultless*, go wet clutch DSG.
/proudoutofwarrantygolfr
*touch wood.
not near near future, unless a deca comes up,
gathering a few parts to fix/upgrade  a couple things in prep for later in the year.
expecting house Oct  so any time after then as I will have somewhere to store/work on car
It's not living with me currently so makes it hard
On 03/05/2017 at 10:31 AM, Birds said:
My prediction of 88E falling post spud (a nothing event) came true
seems like its pretty solid at 0.045. An order there will probably sit there for a week or more until theres a dump for no reason.
still got a while to go. I'll sit and wait till after tax time. No more buying for me. Need to focus on my MMA gambling side gig. live betting online is quite lucrative.
So just got a over due notice from foxtel..
for 1 cent....
yeah that was worth them sending a letter and not just adding to the next bill
(must have had a typo when paying last one and put 13c at end not 14..)
Sounds like there is Per User Shaping and quota...
If you're going through 500mb in 5 minutes, turn down the quality of the video until it all looks like japanese porn.
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
