13 minutes ago, TiTAN said:
Ducatti 1098/1198 motor?
Sure, the one from their street fighter
Or a Monster engine
Would be a great soundtrack to back up the car's performance
Another good one would be the ZX14
Someones already done a turbo Hayabusa Elise I think
1 hour ago, Birds said:
Surely has a daily reminder everytime he drives to work
Not me... I'm currently at work, and I'm still in my Pajamas. Working from a home office brings Casual Fridays to the next level.
Leigh, I'll keep it stock for a while. 310kw at the engine is enough grunt for the time being.
lucky! lost my cushy work from home job :(
53 minutes ago, UNR33L said:
Monster engines are trash, gimme a 1299 engine or 1290 KTM engine instead
Cheap*
Much the same torque which is gonna matter most for a "heavy" vehicle. Good luck finding a donor for one of those!
Enjoyed this luxury for a couple of months recently. Deliver the content by the due date and how you go about it / the logistics in between are irrelevant. The way work should be...input > output
13 minutes ago, UNR33L said:
Michael really good deal at the moment on the XPS 15 upper specced one
https://www.microsoft.com/en-au/store/d/dell-xps-15-156-uhd-infinity-tch-i7qc-16gb-512gbssd/8mgjw2m0gmwd/
This is the exact model I have, even down to individual specs.
It's not the latest version of the XPS 15 though, down the bottom is says its an "XPS 15 9950" which doesn't exist. It's showing an XPS 15 9550, the new one is a 9560 which has an i7 7700 instead of the 6700.
7 minutes ago, Daz said:
Yeah mate took it for a spin today, surprised how easy it is to drive. Glad I chose the right box for the car.
I pick the car up in a week then the fun begins :)
I assume clutch to take off and then V8 supercar from there?
Itching to go for a ride in this
  • Like 1
On 5/3/2017 at 4:28 PM, Leroy Peterson said:
its like power/neg/rpm signal.
Not hard. pulsar was not a typical setup, so i never got it running, but someone else with a pulsar did. i dunno. I dont need it anymore. so its $40 if you want it. Got manual and box for it, maybe 30cm of wire and its the flat type, not the curved type. its quite a good unit. can set custom rpm increments and will use lights to show battery voltage when on Acc.
Also f**k this hotel internet. uses a Mikrotik router of some sort... using a release from 2015 so it cant be that old... repeated speedtests says everything is fine, pulls decent speed, but every 10mins or so it just wont load webpages. I had a download running and it was stable at 200kbs, then spiked to 1000. all the while google would time out. Owner says the router cuts you off if you breach 500mb in an hour, but i can barely use it for 5mins without problems.
Oh noes how will you be able to watch obscure C movie clips with that connection
That's actually an awesome movie. Recommended.
Is browsing the Internet too much to ask for? If I want movies I got a portable HDD. UFC research means watching fights too.
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
