Bought heaps off scorptec back in the day, but centre com is sort of on my way home from work... I'll get this thing off ebay, just wanna get shit off the SSD before I send it to msi and they wipe it...
Even if they fix it, it's not really good enough... One minute you're using your laptop, the next you've lost your data through no fault of your own...
I used to have an awesome backup method, had a backup folder on my NAS at home with mostly pictures / documents in it, would replicate upto my 'One Drive for Business' (1TB) cloud storage. Gotta set it up again since moving jobs I've got a new O365 account..
Most people don't backup until they've been stinged with a Virus or hardware failure etc.
Edited by UNR33L
Even if I don't back up before I send it off there'll be minimal loss... Pretty much everything is on my network hard drive.. Got all the shit off the sata, just wanna double check the SSD in case I've got shit on there..
Leigh pls confirm the eBay links above are what I need so I can order one..
Pls respond
Whats going on in 29 days with 88e? read some threat on hotcopper.. lol
Results or confirmation of spud. I'm not too sure on exact details, but people are expecting flow estimations and permeability information etc.
Which is ironic since everyone on 88E hotcopper is a f**king spud.
So basically it will either jump up ~50% or drop 50% that day?
When significant results come in it will either ten bag like last time or you'll lose pretty much all of your money
This is the roulette of share trading, but with a bit of a preview of what numbers will come up
Friend has an unlimited Amazon cloud storage account (think it's $60 a year) hooked up to his synology 12 Bay nas.
Took a while but the whole things replicated to Amazon in case something goes wrong/stolen etc.
It's a great solution to hook your nas up to cloud storage for offsite and some will roll back changes if you get ransomware for example, any change after x time is just wiped out and you download it from them, have done this with Dropbox before.
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
