33 minutes ago, TiTAN said:
Friend has an unlimited Amazon cloud storage account (think it's $60 a year) hooked up to his synology 12 Bay nas.
Took a while but the whole things replicated to Amazon in case something goes wrong/stolen etc.
It's a great solution to hook your nas up to cloud storage for offsite and some will roll back changes if you get ransomware for example, any change after x time is just wiped out and you download it from them, have done this with Dropbox before.
Beauty of slow aussie uploads means if you get ransomware it'll take ages to replicate anyway haha
12 minutes ago, dezz said:
Could probably find some spare cloud space where I work...
Typically you can link up your NAS to dropbox,onedrive,google drive (just google your model and what you can do with it) most offer a few hundred gig free anyway which is fine for your typical backup of important holiday pictures, documents etc.
Something to try and work out if you get the chance and can be f**ked
Otherwise yeah like you've been doing copy stuff to it from your laptop so you've got it in 2 locations, the disadvantage of that is if you get robbed or house burns down all your data gone.
Edited by UNR33L
Ordered an ebay 2000w generator for tyre warmers @ the track Michael - seeing as you're a sparky, am I gonna die using it?
http://www.ebay.com.au/itm/122413496619?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Don't get me wrong would of loved a Honda or Yamaha one.. but they're like $2k
I'm more interested in where you're doing track days that don't have power available..
I got you wrong
Hope you got a warranty
you see some many of these abandoned after Bathurst as didn't make it through the weekend
plus super noisy and forget 2000watts. Maybe a quick peak but yeah serious draw will kill them
reason the yam/Honda cost more
Murray Valley, Broadford (race days where you need to pay for garage or limited availability), South Morang Gokart track etc.
Edited by UNR33L
Yeah one year warranty, she'll be right looked at some reviews. The warmers will only draw about 1000watts this thing is rated for 1700 running.
Bathurst probably full of drunk people overloading them I guess? Mate of mine got an Aldi one and still going strong
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
