3 hours ago, Daz said:
Need a ser 3 as apparently they are different
http://www.wiringspecialties.com/unrbwihatupr.html
Can confirm with these guys if they're different, but I'm pretty sure they're the same as it's the exact same engine with no extra sensors.
f**k 88e
My counterstrike skin has gone up in value $100USD since last week
Appears to be a bit of a price fixing - someone bought up all the case hardened stat trak karambits and relisted them for thousands of dollars, so genuine sellers have listed theirs for much less but still more than they were a week or so ago. Good times.
I can't believe people pay good money for that shit. And it's the gayest looking knife ever.
Even though I was watching the ESL matches last week in Sydney and made money live betting the rounds....
51 minutes ago, UNR33L said:
Shit knife m8
Skins don't get da kills
Skins get the money and if scarface has taught me anything, you'll soon find yourself the women
I never watched it all the way through though, so I assume happy endings for all
I used to think so too, but, since I'm making money off them, I say let them spend their Christmas money
I actually like the look of that one, but it's rarity that decides the value
Don't know how the whole skin economy hasn't been shut down yet by underage gambling laws, it's as pure as gambling gets
valve pls.
It was brought up in Europe I think.
5 minutes ago, dezz said:
Should you get the original windows CD when you buy a new laptop / computer with Windows installed?
not any more.
shit 3 laptops in our house not one has CD/DVD so would not be usefull.
should have a Certificate sticker on it and a copy of the installer on the drive.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
