2 hours ago, baron_von_bootsector said:
That old Sun gear was pretty much unkillable - I have seen a few V240's with similar uptimes but they were not still hosting mission critical services :)
I miss that kind of gear and the awesome service you got before Oracle bought the company.
yeah the ultra 10 were solid....if you kept power to them,  we had an issue where the HDD got thermal shock if you powered them down.
so stupid reliable till you rebooted.  we imaged drive prior to reboot as we ended up with about a 1 in 3 chance the HDD would not spin back up.
2 hours ago, TiTAN said:
I installed windows 98 se on a gigabyte iram back in the mid 2000s.
Amazing bootup speed.
Took about 19 seconds from power button press to desktop, and about 15 seconds of that was the bios, This was before you could get an ssd.
still the most reliable windows I've touched.
most of what I touch now is *NIX so not had to support M$ setup for a bit
Definitely had similar issues with the old SCSI drives in V240's when we had to move them but if you left them running they were bulletproof apart from the tiny twin 20mm fans on the heatsink. We had it down to the point where we could slide the box out on the rails, pop the lid and do a replacement of the busted fan while the box was live as they were so easy to work on.
Had hands down the best system ever in those machines if you ever had to replace / migrate them - all of the system ID info, MAC's, ALOM settings etc were all kept on a little smartcard in the front of the machine, just plug the replacement chassis in, swap the drives over into the same bays, swap the smartcard and power on :)
I preferred win 8/8.1 over the Windows 10 start menu.
I hate Win10 start menu with a god damned passion, to the point where it's made me not care about the entire thing and left the start menu in a complete mangled heap and I just search for everything now.
It just used to be so nice and organizable in the way you wanted it to be, now its just.. got options you can't undo, apps you can't remove, nested folders that show the way MS wants and jesus christ it irritates me.
Hi all,
Real quick one as I know this is the most used thread in the Vic section.
Does anyone know of a Silver R33 GTR on black 18" rims that has been stolen?
I work in Mulgrave opposite the BMW headquarters and a Silver R33 just pulled up exactly where mine was almost stolen from and performed a launch in an otherwise odd location.
The paranoid part of me is suggesting it's the same shithead who tried to take mine. Maybe i'm going overboard and its just someones car being tuned. Does anyone know of this car?
7 minutes ago, Leroy Peterson said:
just watched latest Mighty Car Mods... glad I dont ever have to share a track with them.
Lol blows engine and knows it, pouring out smoke, doesn't think to get off the racing line for half a lap
After spending the better part of a session blocking other cars.
That corner isn't one you want to suddenly find out you have gone over something and can't slow down for.
Sharing the road with their fanbase is bad enough
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
