There's no shortage of second & third tier lenders that will fall over themselves to give people loans at excruciatingly high rates...
Remember Bankruptcy does not mean you can't borrow money, just that you can't be a director and a few other things...
Credit defaults are for the lender to be able to make an informed decision, they don't mean no one will lend to you if you have solid justification
10 hours ago, emts said:
I'm just trying to work out how they get offered 400Kish on low income with a bankrupcy
thought loans were getting harder not easier.
Spose it depends if was a Part 9 or Part 10 insolvency or full bankruptancy
In any case it should stay on the credit history and just mean muchharder to get a loan and should get higher interest rates
Hamish a question since you work at the bank
Do Banks offer mortgage brokers and public the same interest rate?
The commission that mortgage brokers get is that seperate or built into a higher interest rate offered to a mortgage broker from the bank
We offer the exact same products via both channels - some brokers may try to lead clients towards the more expensive product that gives them a better commission however this is actually not allowed as brokers are required to be at arms length from product selection.
The commission is paid by the bank and not the client nor the loan
They will all flag that the client would be considered higher risk and all appear on credit files.
A part IX and X really mean the same thing, the main difference is the expense in applying for the X due to the CPA requirement.
What are the chances that of the two ssds in the laptop, the one I put in the dock first was never used as the other one never reached capacity? Unlikely I'd imagine, but I only tried one of the 2 last night.. I'll try the second one tonight but I'm not expecting anything different..
You are totally the Greg of computers
  • Like 1
Intradastng
That clears it up.
Just thought it was weird when i tried applying for a home loan my broker couldnt match my interest rate with the big fours when i went direct. Maybe just a crap broker.
And shares
computers/shares
computershare
thats jus a lil stock market humour
  • Like 1
It's got 2 x 128gb ssds and the 1TB sata ..just plugged the second ssd into the dock, it came up as E drive straight away but then followed by a 'disk needs to be formatted' message..
Opened disk management and it's showing more info than with the other one... Can anything be recovered from it?
Ummmmmm, the two 128GB SSD's weren't set up as a RAID 0 array were they?
If so, you won't be able to access the data on either of them without them both being plugged in and having a Raid controller that knows what to do with them
  • Like 1
If it has two and they were in raid0, you won't be getting anything off of them without having the same chipset to plug them into. (Basically not going to happen)
raid1 is a better setup to be running if you have the choice, but you only get the space of one drive and you can recover from a dead drive or a dead computer as both drives contain all the same data without requiring the chipset that put it on there to read it.
I disagree with manufacturers selling products with raid0 setups, that shouldn't be an option for most people as they don't understand the risks and drawbacks involved in doing it, just put the one bigger Pci-e ssd in it, it's easily faster than two sata ones anyway.
  • Like 1
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
