Lol so my daughter decided to wash my iPhone... Literally wash under the bathroom tap....
So I pulled out my galaxy 5 and went to use that... Performance was shocking.... Upon investigation noticed there was 4.5gb of complete bullshit loaded into the misc files section...
I'll give you one guess as to what app it was
Pornhub have an app?
  • Like 1
I imagine some sort of app where you enter the meal that you would like to make, it "deconstructs" it and automatically lays out the ingredients in an aesthetically pleasing way on a fence pailing so you can serve it to bearded hipsters.
I can't believe that would be 4.5gb of space though, was it two drives in Raid 0? If so, you're stuffed.
  • Like 1
1 minute ago, Birds said:
I choose humour over sensible truth everytime, hence my answers
ah but you see the porn sites are some of the smartest about security of all internet companies..
no-way they would be silly enough to cache stuff on your phone for you to get in trouble with your work.
If you ever want to see a correct way to manage security/users check out something like Adultshop/sexyland/any porn site.
nengun gets hacked no big deal..esp if you have different passwords for each site (which we all have right...)
but XXX site gets hacks and it's much worse PR and most likely out of business.
not so much ashley madisen however
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
