I made the mistake of turning on the TV before moto gp and it hooked me in a bit because it was so funny.
Speaking of moto GP - RIP Nicky Hayden :(
Got a signed framed picture of him in my study, nohomo.
15 minutes ago, Odium said:
19 dead, 50 injured at a Terrorist attack on an Ariana Grande concert in Manchester, suicide bomber with a Bolt/Nail Bomb. :( Lots of kids
This world has gone mad :(
Yep gonna be a sad place to be for the upcoming generations if this stuff continues..
I guess it's still better than the wars in the past
Edited by UNR33L
These kind of attacks have been commonplace in the Middle East for decades
Significant increase in Europe over the last 5-10 years
Imported people > imported problems
Whether pro-refugee people want to admit it or not, the problem simply would not exist in these locations if these countries didn't have such open border policies that allow the bad seeds to flow in with the goods
That religion is not compatible with western values
11 minutes ago, Birds said:
Got nothing on a chateau le blanc 68
Which by the way is supposed to be served chilled
Nothing annoys me more than when it is served at room temperature....
what do they think we are? Animals?
  • Like 1
10 minutes ago, Odium said:
Doesn't matter if it's corked... Sell it for $1000+ and let the new owner find that out themselves.
I feel that you don't know Hamish like I do
  • Like 1
RIP actual comedy
  • Like 1
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
