7 hours ago, TiTAN said:
So a massive gate and massive sliding/folding glass doors across the whole back of the place?
It seems like a fine stage from which to show off your efforts in the gym, at least thats the first reason you would want it that comes to mind.
24 minutes ago, emts said:
small side garden I see to work on.
the empty lot next door is that part of the park or will some-one build on it?
Park - only have one neighbour.
first home buyers duty reduction. you get 50% off if it your primary place of residence.
if you put the full 80% down them you don;t need to pay loan mortgage insurance.
simples
You mean 20%
If you put down 80% up front on your first house you have done well.
Going 20% deposit also gets you lower interest rates on top of not having to pay mortgage insurance.
3 minutes ago, TiTAN said:
You mean 20%
With this I got the NAB first home buyer rate which is apparently the best in the market right now - fixed for two years. Also get about $1800 worth of shopping vouchers.
Oh shiiiit
Don't tell him/her that you earned the money with CSGO skins
I prefer independent jewellers (bcoz hipster) because the people and artists actually know what they're doing, and they have no reason to lie to you, the items do all the talking so to speak. It's not just a spec sheet.
I've used e.g. etal in the CBD a couple of times. More designer stuff, but guaranteed unique and brownie points for the wimminz (compliments and envy galore amongst peers). Also got quality custom necklace from Ralf Finch in The Basin (chose a design, picked necklace and got to choose the pearls to use).
Edit: diamond earrings is a tough choice. Easily lost, small, mostly are studs so super subtle.
3 minutes ago, Leroy Peterson said:
Oh shiiiit
I've used e.g. etal in the CBD a couple of times. More designer stuff, but guaranteed unique and brownie points for the wimminz (compliments and envy galore amongst peers). Also got quality custom earrings from Ralf Finch in The Basin (chose a design, picked necklace and got to choose the pearls to use).
"Pearl necklace" sure sure
Ok cool so there's no decent online shop gotta get off my ass and go somewhere?
Mortgage insurance is proportional to your LVR and there's a law of diminishing returns to it, which starts to get awfully shitty when borrowing at high LVRs.
Here's a good example - you have 70k saved up as a first home buyer, it could be allocated as such:
A. 600k property, 5% deposit of 30k, LMI of 26k, stamp duty 15k = initial upfront of ~70k and your LVR is 95% on 570k borrowed
B. 500k property, 10% deposit of 50k, LMI of 9k, stamp duty 11k = initial upfront of ~71k and your LVR is 90% on 450k borrowed
So whilst 100k difference between the purchase price of the two places, the more expensive one actually requires you to borrow 120k more due to money spent on LMI (and some for the extra stamp duty).
One loophole you could use to avoid this - get a relative to borrow and "gift" you enough to make up a 20% deposit and cover the stamp duty - you finance the other 80% = no mortgage insurance and you just service both loans. Or they can go guarantor on the loan and you technically don't need any deposit or LMI.
I'm on 3.81% at the moment, zero annual fees.
Looks like the comparison rate for that 3.69% deal is 4.38%
Pretty sure ubank and loans.com.au are still the actual comparable cheapest as they have no annual fees on their variable rate loans, with a once off few hundred $$ fee if you want to go fixed rate. But you have to have minimum 20% deposit to get those deals.
1 hour ago, UNR33L said:
Where's a good place to buy some diamond earrings?
Don't mind spending a bit but not stupid amounts, birthday present.
Inb4 subtle, VWL6fig, 800k etc.
http://www.bbc.com/news/world-europe-39943470
48 minutes ago, TiTAN said:
Il stick with my pay less interest and fees In the long run than get some vouchers up front plan.
We comparing our loans or what was available to me at the time?
It was available to you too? You said you went in on 20% or more deposit?
Talking about the rate; I have no idea when you obtained a loan.
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
