Procharge.
Saw a rolls Royce ghost stuck in traffic on the Monash last night, had plenty of time to admire it. f**k it's such a baller car. Needs work though, and roof/profile is a bit tall.
Had white HID fog light things in the front bar, but the headlight parkers were yellow. Ewww. And because of the pointy shaped bonnet, to change the headlight globes is probably an engine out job lol
1 hour ago, UNR33L said:
nothing quite says looking after your customer than putting a customers Twin turboed car on your page also showing their P-plates and rego....
What's to say that car even has the kit? Could just be a photo they found of the generation of car they are marketing it for.
17 hours ago, dezz said:
Mate with the aftermarket charged ve gts (which he just sold to replace with a brand new gts with W507 kit, all whilst unemployed)swears by Magnuson chargers (I think)... Side note, mine is the 6.2L..
If you've never had supercharged v8 before give it a go :P easy skids & instant power, whine is good too.
Don't get me wrong love mine but after nearly 6 years ownership ready to get back into a turbo for something different, that's only cos of how long I've had it.
If fuel economy is a concern, a positive displacement Supercharger (what Magnuson offer) will use more fuel all the time.
It will make a lot of power in the low to midrange but will lose out up top to the turbos or centrifugal superchargers, the advantage being positive displacement superchargers are almost lag free and make near their full boost a fraction of a second after you open the throttle enough to close the bypass valve.
Just depends what you want, the positive displacement Supercharger will feel like you have a couple extra L of displacement, the turbos or centrifugal need you to get the revs up a bit before they show what they can do so they tend to be similar in the midrange and then take the advantage in the top end.
Install wise, Superchargers are much simpler than any turbo kit.
  • Like 1
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
